[postgis-users] ST_AsRaster vs raster2pgsql
Pierre Racine Pierre.Racine at sbf.ulaval.ca
Tue Mar 4 15:33:08 PST 2014
You can set the pixeltype and the extent in ST_AsRaster(). You seems also to have a different nodata value that you can also set in ST_AsRaster(). So a bit of reading about ST_AsRaster() and experiment and you'll should get what you want.
Pierre
> -----Original Message-----
> From: postgis-users-bounces at lists.osgeo.org [mailto:postgis-users-
> bounces at lists.osgeo.org] On Behalf Of georgew
> Sent: Tuesday, March 04, 2014 4:55 PM
> To: postgis-users at lists.osgeo.org
> Subject: Re: [postgis-users] ST_AsRaster vs raster2pgsql
> Thank you Pierre, after adding constraints I get:
> "NZTPU";"public";"bk30_saga";"rast";2193;5;-
> 5;4801;5784;TRUE;FALSE;1;"{32BF}";"{-
> 99999}";"{f}";"010300002091080000010000000500000000000080DD0F3
> A41CECF067D3C72554100000080A26D3A41CECF067D3C7255410000008
> 0A26D3A41CECF067DFE55554100000080DD0F3A41CECF067DFE5555410
> 0000080DD0F3A41CECF067D3C725541"
> "NZTPU";"public";"bk30_dem2";"rast";2193;5;-
> 5;4800;5783;TRUE;FALSE;1;"{8BUI}";"{0}";"{f}";"010300002091080000010
> 000000500000000000000E00F3A41000000003C72554100000000A06D3
> A41000000003C72554100000000A06D3A4100000040FF5555410000000
> 0E00F3A4100000040FF55554100000000E00F3A41000000003C725541"
> much better! but not identical. The blocksize is slightly different, the
> pixel type and no_data value are different and the  extent geometry is also
> slightly different, I assume all due to the pixel type being generated
> differently. Using st_metadata and st_bandmetadata I get:
> "(1707997.5,5622001.95354076,4801,5784,5,-5,0,0,2193,1)";"(32BF,-
> 99999,f,)"
> saga
> "(1708000,5622000,4800,5783,5,-5,0,0,2193,1)";"(8BUI,0,f,)"
> dem2
> Any suggestions as to what I can do to make them identical?
> View this message in context: http://postgis.17.x6.nabble.com/ST-
> AsRaster-vs-raster2pgsql-tp5005827p5005830.html
> Sent from the PostGIS - User mailing list archive at Nabble.com.
> postgis-users mailing list
> http://lists.osgeo.org/cgi-bin/mailman/listinfo/postgis-users
