[postgis-users] postgis topology performance
Rémi Cura remi.cura at gmail.com
Thu Mar 20 05:39:53 PDT 2014
Hey,
addlinestring is topology.topogeo_addlinestring(atopology character
varying, aline geometry, tolerance double precision DEFAULT 0).
My version : POSTGIS="2.2.0dev r12325" GEOS="3.5.0dev-CAPI-1.9.0 r3963"
PROJ="Rel. 4.8.0, 6 March 2012" GDAL="GDAL 1.11dev, released 2013/04/13"
LIBXML="2.8.0" TOPOLOGY RASTER
PostgreSQL 9.3.3 on i686-pc-linux-gnu, compiled by gcc (Ubuntu/Linaro
4.6.3-1ubuntu5) 4.6.3, 32-bit
About your idea,
it was our first intend, hence the test with manually using
"topology.addnode(atopology character varying, apoint geometry)",
then manually adding the line : topology.st_addedgemodface(atopology
character varying, anode integer, anothernode integer, acurve geometry).
In an ideal world we would have then used polygonize, but as you said there
is no way to build only adjacency without faces.
In my test , adding points and generating the table for line insertion was
10 sec, the other 70 sec being for line insertion.
I don't understand your last question, do you mean just fill the table
manually without computing adjacencies?
Cheers,
Rémi-C
2014-03-19 19:08 GMT+01:00 Sandro Santilli <strk at keybit.net>:
> On Wed, Mar 19, 2014 at 06:43:21PM +0100, Rémi Cura wrote:
> > Hey,
> > We tried several way to load an already topologically correct shapefile
> > into postgis topology .
> > 10k lines loaded
> > _Using totopogeom : 750 sec
> > _Using addlinestring : 246 sec
> > _Manually using addnode and st_addedgemodface : 86 sec.
> > Still very slow  :-/
> > Considering manually filling table /and/or using GEOS/or using grass
> loader.
> Interesting numbers, thanks.
> By "addlinestring" you mean TopoGeo_addLinestring ?
> Is this with postgis trunk ?
> Note that ST_AddEdgeModFace (called by TopoGeo_addLinestring)
> still performs checks to verify the line you add does not
> cross othe redges. There's currently no API exposed for simply
> adding the linking attributes (face left/right and next edges).
> I was thinking that one idea could be to manually insert all
> the nodes and edges and then have a function to "polygonize"
> the supposedly pre-noded resultance set. This would be pretty
> much the same model used by GEOSPolygonize (requires pre-noded
> input) and would probably be faster for batch constructions.
> To complete the picture, how long does it take to simply insert
> all your lines as edges ? So we get a feeling of IO and referential
> integrity checks cost...
> --strk;
> postgis-users mailing list
> postgis-users at lists.osgeo.org
> http://lists.osgeo.org/cgi-bin/mailman/listinfo/postgis-users
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20140320/4d4ccd84/attachment.html>
