[postgis-users] pgsql2shp : failing to output 3D
Rémi Cura remi.cura at gmail.com
Mon Mar 31 08:25:44 PDT 2014
it outputs 2.
creation of the table is more than explicit :
DROP TABLE IF EXISTS registration_joined_with_trajectory;
            CREATE TABLE registration_joined_with_trajectory (
                ,geom geometry(LinestringZ,931008)
                ,geom_surf geometry(PolygonZ,931008)
What do you think?
Cheers,
Rémi-C
2014-03-31 17:14 GMT+02:00 Sandro Santilli <strk at keybit.net>:
> On Mon, Mar 31, 2014 at 05:06:57PM +0200, Rémi Cura wrote:
> > Hey,
> > my pgsql2shp doesn't output 3D (but 2D).
> > Am I missing something ?
> > /usr/lib/postgresql/9.3/bin/pgsql2shp -f registration_surf_3D -h
> localhost
> > -p 5433 -u postgres -P uGuess -g geom_surf -r import_xml
> > public.registration_joined_with_trajectory
> > I have the latest postgis/geos/postgres/gdal.
> > Of course ST_AsText output 3D geometry,
> > the table is defined as geometry(polygonZ, XXXX)
> What does this give you ?
>  SELECT max(ST_zmflag("geom_surf"::geometry))
>  FROM public.registration_joined_with_trajectory;
> --strk;
> postgis-users mailing list
> postgis-users at lists.osgeo.org
> http://lists.osgeo.org/cgi-bin/mailman/listinfo/postgis-users
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20140331/0419fda9/attachment.html>
