[postgis-users] PostGIS 2.1.2 and 2.0.5 released
Stephen Mather stephen at smathermather.com
Mon Mar 31 12:53:24 PDT 2014
I thought you were joking at first, and then read your affiliation... .
On Mon, Mar 31, 2014 at 3:45 PM, Gerry Creager - NOAA Affiliate <
gerry.creager at noaa.gov> wrote:
> I'm not sure I'd call it God's country (on either your part or mine). I
> chose to live in Oklahoma because... that's where the severe storms are.
> On Mon, Mar 31, 2014 at 1:24 PM, Paul Ramsey <pramsey at cleverelephant.ca>wrote:
>> Tulips and cherry blossoms here in God's land.
>> If you chose the wrong place to live, there's not much we can do for
>> you... :)
>> http://en.es-static.us/upl/2014/03/north-america-winter-2014.jpg
>> On Mon, Mar 31, 2014 at 9:57 AM, Gerry Creager - NOAA Affiliate
>> <gerry.creager at noaa.gov> wrote:
>> > Does your first line imply that temperatures have risen above the
>> freezing
>> > level, for at least carbon dioxide, north of, say, Chicago?
>> > On Mon, Mar 31, 2014 at 8:40 AM, Paul Ramsey <pramsey at cleverelephant.ca
>> > wrote:
>> >> Hi all,
>> >> Spring is here (in the northern hemisphere, mostly) and that means it's
>> >> time to release some fresh patch releases of PostGIS 2.1 and 2.0
>> branches!
>> >>   http://download.osgeo.org/postgis/source/postgis-2.1.2.tar.gz
>> >>   http://download.osgeo.org/postgis/source/postgis-2.0.5.tar.gz
>> >> For detailed changes, check out the respective release notes:
>> >>   http://svn.osgeo.org/postgis/tags/2.1.2/NEWS
>> >>   http://svn.osgeo.org/postgis/tags/2.0.5/NEWS
>> >> Users of the 2.1 branch should strongly consider upgrading: there are
>> some
>> >> crashers fixed in this release, and there are important fixes to the
>> >> geography (spherical) distance calculations that repair incorrect
>> handling
>> >> of multi-geometries. Remember this is a patch release, so upgrading
>> just
>> >> involves installing the new software, you don't need to do a dump and
>> >> restore, just install and "ALTER EXTENSION postgis UPDATE TO '2.1.2';
>> >> Thanks!
>> >> Your PostGIS PSC
>> >> _______________________________________________
>> >> postgis-users mailing list
>> >> postgis-users at lists.osgeo.org
>> >> http://lists.osgeo.org/cgi-bin/mailman/listinfo/postgis-users
>> > Gerry Creager
>> > NSSL/CIMMS
>> > 405.325.6371
>> > "Big whorls have little whorls,
>> > That feed on their velocity;
>> > And little whorls have lesser whorls,
>> > And so on to viscosity."
>> > Lewis Fry Richardson (1881-1953)
> Gerry Creager
> NSSL/CIMMS
> 405.325.6371
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20140331/c5659a12/attachment.html>
