[postgis-users] ST_MakeLine() woes
georgew gws293 at hotmail.com
Sat May 10 23:34:10 PDT 2014
Hi, I have the following code (based on the blog:
http://blog.mathieu-leplatre.info/drape-lines-on-a-dem-with-postgis.html):
WITH line AS
-- From an arbitrary line
(SELECT geom from foot_cl where (sheet='AT24' AND sid=463)),
cells AS
-- Get DEM elevation for each intersected cell
(SELECT ST_Centroid((ST_Intersection(at24.rast, line.geom)).geom) AS geom,
(ST_Intersection(at24.rast, line.geom)).val AS val
FROM at24, line
WHERE ST_Intersects(at24.rast, line.geom)),
-- Instantiate 3D points, ordered on line
points3d AS
(SELECT ST_SetSRID(ST_MakePoint(ST_X(cells.geom), ST_Y(cells.geom), val),
2193) AS geom
FROM cells, line)
select * from points3d
which produces a series of points with the correct shape of the line.
If however I replace the last  line with:
SELECT ST_MakeLine(points3d.geom ORDER BY
ST_Distance(ST_StartPoint(line.geom), cells.geom)) FROM points3d,line,cells
I end up with a line shape which bears only a faint resemblance to what it
should be, i.e. the points are not in the correct sequence.
What is wrong with what I am doing and how can I get the points in the
correct sequence?
Many thanks
View this message in context: http://postgis.17.x6.nabble.com/ST-MakeLine-woes-tp5006266.html
Sent from the PostGIS - User mailing list archive at Nabble.com.
