[postgis-users] ST_MakeLine() woes
Rémi Cura remi.cura at gmail.com
Tue May 13 02:17:18 PDT 2014
Sorry it didn't work :-( . Can you check that temp_id is not always 1?
It is more that this approach is flawed
_depending on the raster resolution and the small turn in your line (fixe =
simplify line).
_anyway, you are constructing a new line from centroid, and not putting the
height information on the old line (see end of the message)).
Can you try to spatially filter your line : with the same code, change just
the beginning
WITH line AS
-- From an arbitrary line
(SELECT ST_Simplify(geom,2*your_raster_cell_size) from foot_cl where
(sheet='AT24' AND sid=463)),
cells AS ....
A safer way to do it would be for instance:
find the pixel under the line
transform those pixels into polygons along with height value
(ST_PixelAsPolygons)
cut the line with those polygons (create new points at each enter/exit of
pixels)
add the height information of each polygon into the line parts.
renode the line by assembling in the correct order the line parts.
A suggestion of code for it:
WITH rast AS ( --getting a raster, and a diag line for this raster
        SELECT *  --,
ST_Intersection(rast,line)--unnest(regexp_split_to_array(ST_Summary(rast),'\n'))
        FROM
test_raster.test_temp_raster,ST_SetSRID(ST_GeomFromText('Linestring(651050.
6860677,651055 6860682)') ,931008) AS line
        WHERE rid = 273143
        LIMIT 1
    ,pix_under_line AS ( --get the pixels that are covered by the line,
transform the pixels into square (pylgon), keep the value of the band 1
(heigth is supposed to be here)
                        --this is suboptimal and could be replacer by using
st_intersection
        SELECT pix.*, line
        FROM rast,ST_PixelAsPolygons(rast,1) AS pix
        WHERE  ST_Intersects(pix.geom,line)=TRUE
            --AND pix.val!=0 --if raster from interpolation, no need to
keep wrong parts
    ,cutting_line_with_pix AS (--splitting the line with the pixels in
order to obtain multiple parts of the line, each covering one pixel
                            --(see
https://github.com/Remi-C/PPPP_utilities/tree/master/postgis for
rc_split_multi)
        SELECT  ST_Dump(rc_Split_multi(min(line),
ST_Union(ST_Boundary(geom)),0.01)) AS splitted_line
        FROM pix_under_line
    ,splitted_line AS ( --filtering the obtained parts of line to remove
ghost created by precision error and point-line
        SELECT (splitted_line).path, (splitted_line).geom, ST_AsText(
(splitted_line).geom)
        FROM cutting_line_with_pix
        WHERE ST_Length((splitted_line).geom)>0.001
    ,sl_and_pix AS ( --for each parts of line, get the pixel polygon that
it covers, along with the value of the pixel. Add this value to the parts
of line
        SELECT DISTINCT ON (path) sl.*,  pul.*,
ST_AddMeasure(sl.geom,pul.val,pul.val) AS l_heigth
        FROM splitted_line AS sl, pix_under_line AS pul
        WHERE  ST_Intersects(sl.geom,pul.geom)=TRUE
        ORDER BY path ASC, ST_Length(sl.geom) DESC
    )--fusion the line parts to create a single line (don't use ST_Union,
it drops the M value)
    SELECT ST_Astext(ST_MakeLine(l_heigth ORDER BY path ASC) )
    FROM sl_and_pix
Cheers,
Rémi-C
2014-05-13 1:08 GMT+02:00 georgew <gws293 at hotmail.com>:
> thanks Remi, attached is the result after running your code, no change
> unfortunately.
> I had to make some slight changes to the code to make it work. The image
> has
> the code.
> However you also say that my approach is not as robust as it could be. Any
> suggestions on how to make it more robust?
> newline.png <http://postgis.17.x6.nabble.com/file/n5006277/newline.png>
> http://postgis.17.x6.nabble.com/ST-MakeLine-woes-tp5006266p5006277.html
> Sent from the PostGIS - User mailing list archive at Nabble.com.
> postgis-users mailing list
> postgis-users at lists.osgeo.org
> http://lists.osgeo.org/cgi-bin/mailman/listinfo/postgis-users
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20140513/6e4d3a4b/attachment.html>
