[postgis-users] Uploading data to a different server via command prompt
Shane StClair shane at axiomalaska.com
Wed May 14 09:20:50 PDT 2014
Hi Mark,
shp2pgsql just generates SQL statements to create the shapefile data. psql
actually executes those statements, so that's where you want to specify
connection parameters for the other server.
http://www.postgresql.org/docs/9.2/static/app-psql.html
So something like:
    for %%f in (*.shp) do shp2pgsql -d -I -s 103749 -W LATIN1 %%f %%~nf |
psql -w -h 192.168.1.50 -U postgres -d lyongis
You can put your authentication credentials into a .pgpass file to avoid
retyping the password for each shapefile.
http://www.postgresql.org/docs/9.3/static/libpq-pgpass.html
Also note that your remote server will need to be configured to allow
external connections and password authentication for the postgres user.
Best,
Shane
On Wed, May 14, 2014 at 8:50 AM, Mark Volz <MarkVolz at co.lyon.mn.us> wrote:
> Hello,
> I understand that I can use shp2pgsql to load shapefiles on the localhost.
>  I would like to know load data onto another server, and I would like to
> verify that I am doing everything correct.  Specifically:
> 1)  How I can adjust this code so that I can update the gis data on a
> different server?
> 2)  How will I specify the password on a different machine?
> 3)  Do I need to do anything in addition to this to create spatial indexes?
> Current code that I am using to load a directory of shapefiles.
> set PATH=C:\Program Files\PostgreSQL\9.2\bin;%PATH%
> for %%f in (*.shp) do shp2pgsql -d -I -s 103749 -W LATIN1 %%f %%~nf | psql
> -w -U postgres -d lyongis
> Thanks
> Sincerely,
> Mark Volz, GISP
> Lyon County GIS Coordinator
> postgis-users mailing list
> postgis-users at lists.osgeo.org
> http://lists.osgeo.org/cgi-bin/mailman/listinfo/postgis-users
Shane StClair
Software Engineer
Axiom Consulting & Design
http://www.axiomalaska.com
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20140514/721e54fc/attachment.html>
