[postgis-users] Restoring a dump
Jayson Gallardo jaysontrades at gmail.com
Mon May 19 14:02:31 PDT 2014
Yes. The database has rasters. I just tried loading rtpostgis.sql, etc.,
but none of those seemed to help at all. I did load legacy.sql before the
dump as well.
On Mon, May 19, 2014 at 3:54 PM, Jason Mathis
<jmathis at redzonesoftware.com>wrote:
> Do you have raster columns/tables?
> On May 19, 2014 at 2:47:47 PM, Jayson Gallardo (jaysontrades at gmail.com)
> wrote:
>  So, I finally got around to running the restore, but I get this
> following error:
> ERROR:  function st_bandmetadata(public.raster, integer[]) does not exist
> Any ideas?
> On Mon, May 19, 2014 at 12:29 PM, Jason Mathis <
> jmathis at redzonesoftware.com> wrote:
>>  What do you mean, starting from scratch? You have to install
>> postgresql/postgis and then follow the answers/links from sandro. You
>> should be good with that dump.
>>  good luck!
>> On May 19, 2014 at 10:22:38 AM, Jayson Gallardo (jaysontrades at gmail.com)
>> wrote:
>>  Here's the thing, all I have is a dump (postgres_dump_03172014.gz)
>> using pg_dumpall. The server has been reformatted with a clean install of
>> Debian. I haven't even installed Postgres yet. So, what are my options
>> then? I really would hate to start from scratch.
>> On Mon, May 19, 2014 at 10:15 AM, Sandro Santilli <strk at keybit.net>wrote:
>>> On Mon, May 19, 2014 at 09:39:20AM -0500, Jayson Gallardo wrote:
>>> > Hey, all. So, we recently re-did our server. We were previously running
>>> > Ubuntu, and now we are running Debian. I had performed a pg_dumpall on
>>> our
>>> > Postgres database (with PostGIS) and would now like to restore said
>>> dump.
>>> > However, I want to make sure I do it right.
>>> Follow the instructions here:
>>> http://postgis.net/docs/manual-2.1/postgis_installation.html#hard_upgrade
>>> > Since I dumped everything, will I need to create all the databases
>>> before
>>> > restoring the dump?
>>> > I should probably install the Postgis plug-in first, right?
>>> You should create the databases and spatially-enable them
>>> (could be a chance to switch to EXTENSION-based install).
>>> > My dump is pretty big at 101 GB (it contains 3m resolution DEMs of
>>> Iowa).
>>> > Is there anything I need to do in order to minimize errors in the
>>> restore?
>>> I guess you could reinstall each database separately, to at least
>>> be more in control of what fails ...
>>> --strk;
>>>  ()  ASCII ribbon campaign  --  Keep it simple !
>>>  /\  http://strk.keybit.net/rants/ascii_mails.txt
>>> postgis-users mailing list
>>> postgis-users at lists.osgeo.org
>>> http://lists.osgeo.org/cgi-bin/mailman/listinfo/postgis-users
>> This transmission contains confidential and privileged information
>> intended solely for the party identified above. If you receive this message
>> in error, you must not use it or convey it to others. Please destroy it
>> immediately and contact the sender at (303) 386-3955 or by return e-mail
>> to the sender.
> to the sender.
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20140519/2f3f7764/attachment.html>
