[postgis-users] Spurious Results using ST_Split
Jeff Adams - NOAA Affiliate jeff.adams at noaa.gov
Fri May 23 05:28:34 PDT 2014
Thanks for the response Remi-C. Could you please give me a brief overview
of what the workaround would involve? Is this a reported issue?
On Fri, May 23, 2014 at 8:08 AM, Rémi Cura <remi.cura at gmail.com> wrote:
> Hey,
> it looks like a classical precision issue.
> There are some workaround but they are a little bit annoying.
> Cheers,
> Rémi-C
> 2014-05-23 13:46 GMT+02:00 Jeff Adams - NOAA Affiliate <
> jeff.adams at noaa.gov>:
>> Greetings,
>> I have been working with the st_split function and have been receiving
>> strange results. Specifically, I have been using a polygon geometry to
>> split a linestring geometry. After the split I have been using st_within to
>> identify which of the resulting split linestring geometries are inside and
>> which are outside. Sometimes the st_within results are as expected, other
>> times, split linestring geometries that are clearly within the polygon
>> feature (they were created using the polygon as the blade) are not
>> identified as so. When checking in ArcGIS, the features that returned false
>> using the st_within function in PostGIS (but by the nature of how they were
>> created should be within the polygon) are being identified by ArcGIS as
>> being within the polygon. Does anybody know why PostGIS' st_within is
>> returning false with these features? Any workarounds? I am performing this
>> analysis on a fairly large dataset.
>> Thanks in advance...
>> Jeff
>> postgis-users mailing list
>> postgis-users at lists.osgeo.org
>> http://lists.osgeo.org/cgi-bin/mailman/listinfo/postgis-users
Jeffrey D. Adams
Contractor
OAI, Inc.
In support of:
National Marine Fisheries Service
Office of Protected Resources
1315 East West Hwy, Building SSMC3
Silver Spring, MD 20910
phone: (301) 427-8434
fax: (301) 713-0376
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20140523/ff051773/attachment.html>
