[postgis-users] 'Z' Difference between DEM file & PG DEM layer
dandrigo lcelati at latitude-geosystems.com
Mon May 26 13:17:32 PDT 2014
Dear all,
I imported into my postgis database my DEM thanks to raster2pgsql.
After the import, i loaded  my raw dem file (.asc) and my pg dem raster file
into qgis to make sure that the altimetric values ​​were identical.
Unfortunatly, i noticed a z difference between the 2 data (often 3-5 meters,
sometimes more).
Below, you can read my small file comparing the metadata of the 2 data (on
the left, raw dem file; on the right, postgis dem raster) :
Raster_compare.pdf
<http://postgis.17.x6.nabble.com/file/n5006415/Raster_compare.pdf>
Why this difference? How can I do so that my pg data is really identical to
my raw asc file?
In advance, thank you.
Regards.
View this message in context: http://postgis.17.x6.nabble.com/Z-Difference-between-DEM-file-PG-DEM-layer-tp5006415.html
Sent from the PostGIS - User mailing list archive at Nabble.com.
