[postgis-users] function trigger to populate values based on spatial relationships
Alexandre Neto senhor.neto at gmail.com
Tue Oct 14 04:47:01 PDT 2014
Hello Pietro
On Tue, Oct 14, 2014 at 12:39 PM, Pietro Rossin <pierigis at gmail.com> wrote:
> If I try to add values from QGis 2.4 I don't get any message but no value
> is
> added..
> Where is my mistake??
If you add values outside QGIS, does it work? Because the TRIGGER will only
be triggered after you save your edits in QGIS.
> Thanks
> Pietro
> http://postgis.17.x6.nabble.com/function-trigger-to-populate-values-based-on-spatial-relationships-tp5007143.html
> Sent from the PostGIS - User mailing list archive at Nabble.com.
> postgis-users mailing list
> postgis-users at lists.osgeo.org
> http://lists.osgeo.org/cgi-bin/mailman/listinfo/postgis-users
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20141014/051a363f/attachment.html>
