[postgis-users] shp2pgsql -D not working properly
Nicolas Ribot nicolas.ribot at gmail.com
Fri Sep 19 11:03:01 PDT 2014
-D option should appear just after shp2pgsql, not after the shape and table
parameters, no ?
Nicolas
On 19 September 2014 19:29, Rémi Cura <remi.cura at gmail.com> wrote:
> Hey list,
> I'm a bit ashamed to be stuck with a seemingly trivial problem :
> executing
> /usr/lib/postgresql/9.3/bin/shp2pgsql 2_poles.shp cmm.temp_import_poles -D
> output somehting like
> create table
> INSERT INTO "cmm"."temp_import_poles"
> ("label","class","length_[m]","verticality","rotation_[d","gps_time_[s",geom)
> VALUES
> ('1','16','0.0','0.0','0.0','0','01010000C00000E018A0E02341000080D8E52B5A41000000E06E0F49400000000000000000');
> I'm pretty sure this isn't the postgres dump it should be .
> I aim to load shapfile from within the server (COPY PROGRAMM 'shp2...').
> Somebody has a clue about this?
> Cheers,
> Rémi-C
> postgis-users mailing list
> postgis-users at lists.osgeo.org
> http://lists.osgeo.org/cgi-bin/mailman/listinfo/postgis-users
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20140919/fbe33237/attachment.html>
