[postgis-users] {raster}: ST_DumpValues
tomChavakis tomchavakis at gmail.com
Wed Sep 24 04:06:20 PDT 2014
Hello,
I am new at postgis and I don't know if this is the right process about a
possible bug.
I am using the raster extension and the Npgsql adapter dll in order to set
queries.
Firstly I use ST_AsBinary but I had a problem about reading the data from
VStudio because
I can't read WKB format.
Then I use ST_DumpValues(rast) in order to read the values from the database
and at loading raster I use -t 128x128  .
I noticed that the result is less 128*2 +1 Value and the items that missing
from the list are the first column after first row
And the last column of the Array.
I suppose that this is a bug, I think that must return all the Values in
order to be rectangular and know how much items existed at each row.
Thanks in advance
T.Chavakis
This email is free from viruses and malware because avast! Antivirus protection is active.
http://www.avast.com
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20140924/22d93291/attachment.html>
