[postgis-users] Is it possible to do constraint exclusion based on spatial extents?
Stephen Woodbridge woodbri at swoodbridge.com
Sun Aug 2 12:04:31 PDT 2015
I know I can setup table inheritance and constraint exclusion based on
say the state field. But I would like to do this based on geom and the
table extents. How would I do this?
Say for example, I create a roads table, then load data into
roads_area1, roads_area2, etc and these inherit from roads.
For the state abbrv. I might have:
ALTER TABLE roads_area1 ADD CONSTRAINT chk
    CHECK (state IN ('MA', 'ME', 'NH'));
So doing the same based on geom column might look like:
ALTER TABLE roads_area1 ADD CONSTRAINT bbox_chk
CHECK (geom && <????>);
So does this work?
Do I need to do anything special to get postgresql to using constraint
exclusion? What?
How would I set <????>?
These tables are create once and query often, so the extents are not
changing after they are loaded.
Thanks,
   -Steve W
