[postgis-users] Which operators/functions work with circular arcs?
Paragon Corporation lr at pcorp.us
Fri Aug 21 15:21:30 PDT 2015
Andreas,
Sure available and happy too.
Thanks,
Regina
-----Original Message-----
[mailto:postgis-users-bounces at lists.osgeo.org] On Behalf Of Andreas Neumann
Sent: Thursday, August 20, 2015 4:05 PM
To: postgis-users at lists.osgeo.org
Subject: Re: [postgis-users] Which operators/functions work with circular
arcs?
Hi Paul,
Thank you for your  reply. Indeed it would be nice to label the functions
that are safe to use with Circular Arcs. With the soon to be announced
support for display and editing of circular arcs in QGIS it would to keep
them as such in Postgis and still use them for geoprocessing with SQL.
Regina - would you be available for some contracted work to improve tests
and documentation around support of circular arcs?
Andreas
On 20.08.2015 19:17, Paul Ramsey wrote:
> They aren't marked, perhaps Regina could garden test them to find them...
> All the simple functions that take apart geometries, etc, work fine.
> The simple measurements (length/perimeter) work fine As of 2.2 all the
> GEOS-backed functions will "work" (by linearizing the arcs before
> sending them in) The simplification functions won't work, though as of
> 2.2 they too will linearize first.
> The area calculations don't work.
> A comprehensive survey would be most appreciated.
> P
> On Thu, Aug 20, 2015 at 7:30 AM, Andreas Neumann <a.neumann at carto.net>
wrote:
>> Hi,
>> I wonder how I can find out what operators and what functions work
>> with circular arcs? Are they marked in the documentation as such?
>> Thank you for your hints!
>> Andreas
>> postgis-users mailing list
>> http://lists.osgeo.org/cgi-bin/mailman/listinfo/postgis-users
