[postgis-users] Topology & Attributes
Ofer Zilberstein zilberstein.ofer at gmail.com
Sun Feb 8 12:57:16 PST 2015
Much Thanks,
First I will try to understand the join that you did and then try to
implement it...
Ofer
On Sun, Feb 8, 2015 at 12:44 PM, Nicolas Ribot <nicolas.ribot at gmail.com>
wrote:
> Hi,
> When you build the topology, for instance with topology.toTopoGeom(), you
> get back a TopoGeometry object for each polygon added to the topology.
> This TopoGeometry is used to keep a link between your polygon object and
> all the topological elements composing it.
> The "relation" table inside the topo schema holding the topology contains
> the identifier of the topoGeometry object and the identifiers of topo
> elements composing the polygon.
> To get the right and left original polygons from the topology, you make a
> join between edge, relation and pg table:
> (topo_grass is the topo schema, parcelle is the polygon table with a topo
> column containing the TopoGeometry object corresponding to the polygon):
> select e.edge_id, e.left_face, e.right_face,
>   p1.id as left_id, p2.id as right_id
> from topo_grass.edge e
>   join topo_grass.relation r1 on r1.element_id = e.left_face
>   join pe.parcelle p1 on (1, (p1.topo).id) = (r1.layer_id, r1.topogeo_id)
>   join topo_grass.relation r2 on r2.element_id = e.right_face
>   join pe.parcelle p2 on (1, (p2.topo).id) = (r2.layer_id, r2.topogeo_id);
> Nicolas
> On 8 February 2015 at 10:29, Ofer Zilberstein <zilberstein.ofer at gmail.com>
> wrote:
>> Hi,
>> When you build topology from set of connected polygons, the original
>> polygon attributes are not part of the topology model. The model creates
>> MBR face for each original polygon.
>> The edges hold the left & right faces.
>> How or what is the right way to add to the edges the right and left
>> original polygons ?
>> *Ofer Zilberstein*
>>     Mobile: 972-544886873
>>     Skype: ofer.zilberstein
>>     Mail: zilberstein.ofer at gmail.com
>> postgis-users mailing list
>> postgis-users at lists.osgeo.org
>> http://lists.osgeo.org/cgi-bin/mailman/listinfo/postgis-users
*Ofer Zilberstein*
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20150208/efc0871f/attachment.html>
