[postgis-users] ST_Intersection very slow.
John Abraham jea at hbaspecto.com
Thu Feb 19 16:26:15 PST 2015
Thanks for the hint, Rémi.  I'll give it a try, to see if the st_intersection is slow (as compared to just st_intersects).
Here's my EXPLAIN ANALYZE for my 5 zone test:
"Nested Loop  (cost=1.56..80.91 rows=8 width=560) (actual time=3929258.738..19756123.479 rows=29 loops=1)"
"  Join Filter: (_st_intersects(p.geom, n.the_geom) AND ((NOT (p.geom && n.the_geom)) OR (NOT _st_touches(p.geom, n.the_geom))))"
"  CTE sometaz"
"    ->  Limit  (cost=0.00..1.56 rows=5 width=9537) (actual time=0.433..0.576 rows=5 loops=1)"
"          ->  Seq Scan on tazjan2  (cost=0.00..843.09 rows=2709 width=9537) (actual time=0.415..0.511 rows=5 loops=1)"
"  ->  CTE Scan on sometaz n  (cost=0.00..0.10 rows=5 width=80) (actual time=0.460..0.724 rows=5 loops=1)"
"  ->  Index Scan using lancover_polygons_snap_geom_idx on lancover_polygons_snap p  (cost=0.00..12.47 rows=5 width=480) (actual time=0.242..65.640 rows=16 loops=5)"
"        Index Cond: (geom && n.the_geom)"
"Total runtime: 19756143.935 ms"
Here it is explained in layspeak: http://explain.depesz.com/s/dbVi
So, am I reading this right, that it took 5.5 hours to st_intersects 5 (multi)polygons with 29 (multi)polygons, and find the 8 that intersected?  That the index scan was fast (328ms), and returned only a few (16, or maybe 29) of the 998031 polygons, but that the actual intersection afterwards, between just a few polygons, was so very slow?
(The query was this:
with sometaz as (select * from tazjan2 limit 5)
SELECT p.lc_class, n.taz
 , CASE
   WHEN ST_CoveredBy(p.geom, n.the_geom)
   THEN p.geom
   ELSE
    ST_Multi(
      ST_Intersection(p.geom,n.geom)
      ) END AS geom
 FROM lancover_polygons_snap AS p
   INNER JOIN sometaz AS n
    ON (ST_Intersects(p.geom, n.the_geom)
      AND NOT ST_Touches(p.geom, n.the_geom) );
John Abraham
403-232-1060
On Feb 19, 2015, at 11:56 AM, Rémi Cura <remi.cura at gmail.com> wrote:
> Hey,
> you could try to not use CASE (so separate the spatial join from the processing, which is easy to parallelize (assuming you have more than one core )).
> First generate the table with
> CREATE TABLE psatial_mapping_between_lancover_and_taz AS
> SELECT row_number() over() as row_id, p.your_primary_key, n.your_primary_key
>    INNER JOIN tazjan2 AS n
> Then when you have your table, you can do your processing (put into a SQL function , it is cleaner),
> and you parallelize on the "row_id".
> Basically you get min(row_id), ax(row_id), you spearate it into N parts, then execute the parts with your K processes.
> (both bash and python have utilities for this).
> Of course if it is actually the spatial join that is slow, you can also parallelise this.
> (by cutting lancoverinto N pieces for instance )
> Cheers,
> Rémi-C
> 2015-02-19 19:45 GMT+01:00 John Abraham <jea at hbaspecto.com>:
> So I've was running this query for 866000 s (10 days) before I decided to kill it:
> create table taz_and_lancover_10_fast_2 as
>  , CASE
>    THEN p.geom
>    ELSE
>     ST_Multi(
>       ) END AS geom
> Explain shows this, it's using the spatial index:
> "Nested Loop  (cost=0.00..310492.35 rows=483105 width=9973)"
> "  ->  Seq Scan on tazjan2 n  (cost=0.00..843.09 rows=2709 width=9493)"
> "  ->  Index Scan using lancover_polygons_snap_geom_idx on lancover_polygons_snap p  (cost=0.00..21.67 rows=5 width=480)"
> There are 2709 rows in tazjan2 and 998031 rows in lancover_polygons_snap, so I appreciate that it's a bit of a large problem.  But MapInfo was able to do it interactively in a few days and Geomedia was also able to do it in about a day.
> Both MapInfo and Geomedia ran out of memory (8GB machines) until the problem was broken into two regions (North and South), but postgresql seems to be chewing on the problem using only 400MB.  The interactive approach in MapInfo was to divide lancover_polygons_snap by lc_class, to further divide each region into about 10 subproblems.  Perhaps subprobleming this is the way to go?  Can't the query subproblem it based in the indices or would I have to do that manually?
> One potential thing I've realized is that a few of the geometries in tazjan2 are multipolygons, not single polygons.  But it's only a few.  There are a few very large and complex polygons in lancover_polygons_snap, but again, most of the 998031 are simple small polygons, about half would be ST_CoveredBy the polygons in tazjan2 and most of the rest would only overlap two or three of the polygons in tazjan2.
> I must be doing something wrong.  Any hints?
> I have
>  max_connections set to 100 (currently only 11 connections active)
>  work_mem was defaulting to 1MB, I just bumped it to 256MB (machine has 32GB but it's Postgresql9.1 (x86), i.e. 32bit version
>  shared_buffers was 32MB, I am trying 512MB, could go higher
>  effective_cache_size was defaulting to 128MB, I am trying 20GB.
>  random_page_cost was 4.0, this is VMWare virtual server.  I am trying 2.0
> I'm trying an "explain analyze" with just 5 rows of tazjan2, a 5 x 998031 intersection problem with indices shouldn't take that long, should it?  It's been running for a little over an hour.  I'm wondering if the few complex polygons in lancover_polygons_snap are causing the slowness?  Is there some fast way to divide complex polygons, e.g. apply a 1km grid over them?
> PostGISfullversion(): "POSTGIS="2.0.3 r11128" GEOS="3.3.8-CAPI-1.7.8" PROJ="Rel. 4.8.0, 6 March 2012" GDAL="GDAL 1.9.2, released 2012/10/08" LIBXML="2.7.8" LIBJSON="UNKNOWN" (core procs from "2.0.3 r11132" need upgrade) TOPOLOGY (topology procs from "2.0.3 r11132" need upgrade) RASTER (raster procs from "2.0.3 r11132" need upgrade)"
> John Abraham
> postgis-users mailing list
> postgis-users at lists.osgeo.org
> http://lists.osgeo.org/cgi-bin/mailman/listinfo/postgis-users
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20150219/23e1da90/attachment.html>
