[postgis-users] POSTGIS_ENABLE_OUTDB_RASTERS=1: PostGIS won't start (RHEL 6.5)
Bborie Park dustymugs at gmail.com
Wed Feb 25 10:46:59 PST 2015
Philip,
POSTGIS_ENABLE_OUTDB_RASTERS=1 is an environment variable not to be in
postgresql.conf.
The same is true for POSTGIS_GDAL_ENABLED_DRIVERS=ENABLE_ALL
https://wiki.postgresql.org/wiki/PostgreSQL_on_RedHat_Linux
Based upon the above, it looks like you should add
to  /etc/sysconfig/pgsql/postgresql
The above assumes you're using the packages provided by PostgreSQL.
http://www.postgresql.org/download/linux/redhat/
-bborie
On Wed, Feb 25, 2015 at 10:10 AM, Phil Hurvitz <phurvitz at uw.edu> wrote:
> Hi all, I am having trouble starting PostGIS with out-db raster support
> In my /usr/local/pgsql/data/postgresql.conf file I include the line
> after which PostGIS won't start (service postgresql start).
> Software is
> postgis_full_version
>  POSTGIS="2.1.3 r12547" GEOS="3.4.2-CAPI-1.8.2 r3921" PROJ="Rel. 4.7.1, 23
> September 2009" GDAL="GDAL 1.11.2, released 2015/02/10" LIBXML="2.7.6"
> TOPOLOGY RASTER
> Also PostGIS won't start when I specify
> Any help would be appreciated!
> -P.
> Philip M. Hurvitz, PhD | Research Assistant Professor | UW-CBE
> Urban Form Lab  | 1107 NE 45th Street, Suite 535  | Box 354802
> University of Washington, Seattle, Washington  98195-4802, USA
> phurvitz at u.washington.edu | http://gis.washington.edu/phurvitz
> "What is essential is invisible to the eye." -de Saint-Exupéry
> postgis-users mailing list
> postgis-users at lists.osgeo.org
> http://lists.osgeo.org/cgi-bin/mailman/listinfo/postgis-users
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20150225/f98eb6fb/attachment.html>
