[postgis-users] POSTGIS_ENABLE_OUTDB_RASTERS=1: PostGIS won't start (RHEL 6.5)
Bborie Park dustymugs at gmail.com
Wed Feb 25 12:56:17 PST 2015
Going back a few messages, it looks like you're specifying these out-db
rasters with relative paths. Use absolute paths.
Instead of:
raster2pgsql -I -C -e -Y -F -d -R -s 2926  ./slope/slope_ps.tif gis.slope |
psql osm_test
Use:
 /ABSOLUTE/PATH/TO/slope/slope_ps.tif gis.slope | psql osm_test
PostgreSQL cannot access paths that were relative to the current working
directory when calling raster2pgsql.
Also, specify a tile size.
-bborie
On Wed, Feb 25, 2015 at 12:51 PM, Phil Hurvitz <phurvitz at uw.edu> wrote:
> Thank you, Bborie. This seems to be a partial solution (at least now
> PostGIS isn't complaining about the out-db raster). But now I get a
> different problem, which is that attempting to access the out-db raster
> makes the connection choke:
> select st_summarystats(rast) from slope;
> The connection to the server was lost. Attempting reset: Failed.
> -P.
> Philip M. Hurvitz, PhD | Research Assistant Professor | UW-CBE
> Urban Form Lab  | 1107 NE 45th Street, Suite 535  | Box 354802
> University of Washington, Seattle, Washington  98195-4802, USA
> phurvitz at u.washington.edu | http://gis.washington.edu/phurvitz
> "What is essential is invisible to the eye." -de Saint-Exupéry
> On 2/25/2015 12:41, Bborie Park wrote:
>> Ah. I use a script similar to this.
>> In the following block...
>> start)
>>      su - $PGUSER -c "$DAEMON -D '$PGDATA' &" >>$PGLOG 2>&1
>> You'll want to modify the su line to be like:
>>      su - $PGUSER -c "POSTGIS_ENABLE_OUTDB_RASTERS=1
>> POSTGIS_GDAL_ENABLED_DRIVERS=__ENABLE_ALL $DAEMON -D '$PGDATA' &"
>>  >>$PGLOG 2>&1
>> See if that works...
>> -bborie
>> On Wed, Feb 25, 2015 at 12:29 PM, Phil Hurvitz <phurvitz at uw.edu
>> <mailto:phurvitz at uw.edu>> wrote:
>>     Certainly!
>>     ! /bin/sh
>>     # chkconfig: 2345 98 02
>>     # description: PostgreSQL RDBMS
>>     # This is an example of a start/stop script for SysV-style init, such
>>     # as is used on Linux systems.  You should edit some of the variables
>>     # and maybe the 'echo' commands.
>>     # Place this file at /etc/init.d/postgresql (or
>>     # /etc/rc.d/init.d/postgresql) and make symlinks to
>>     #   /etc/rc.d/rc0.d/K02postgresql
>>     #   /etc/rc.d/rc1.d/K02postgresql
>>     #   /etc/rc.d/rc2.d/K02postgresql
>>     #   /etc/rc.d/rc3.d/S98postgresql
>>     #   /etc/rc.d/rc4.d/S98postgresql
>>     #   /etc/rc.d/rc5.d/S98postgresql
>>     # Or, if you have chkconfig, simply:
>>     # chkconfig --add postgresql
>>     # Proper init scripts on Linux systems normally require setting lock
>>     # and pid files under /var/run as well as reacting to network
>>     # settings, so you should treat this with care.
>>     # Original author:  Ryan Kirkpatrick <pgsql at rkirkpat.net
>>     <mailto:pgsql at rkirkpat.net>>
>>     # contrib/start-scripts/linux
>>     ## EDIT FROM HERE
>>     # Installation prefix
>>     prefix=/usr/local/pgsql
>>     # Data directory
>>     PGDATA="/usr/local/pgsql/data"
>>     # Who to run the postmaster as, usually "postgres".  (NOT "root")
>>     PGUSER=postgres
>>     # Where to keep a log file
>>     PGLOG="$PGDATA/serverlog"
>>     # It's often a good idea to protect the postmaster from being killed
>>     by the
>>     # OOM killer (which will tend to preferentially kill the postmaster
>>     because
>>     # of the way it accounts for shared memory).  Setting the
>>     OOM_SCORE_ADJ value
>>     # to -1000 will disable OOM kill altogether.  If you enable this,
>>     you probably
>>     # want to compile PostgreSQL with "-DLINUX_OOM_SCORE_ADJ=0", so that
>>     # individual backends can still be killed by the OOM killer.
>>     #OOM_SCORE_ADJ=-1000
>>     # Older Linux kernels may not have /proc/self/oom_score_adj, but
>> instead
>>     # /proc/self/oom_adj, which works similarly except the disable value
>>     is -17.
>>     # For such a system, enable this and compile with "-DLINUX_OOM_ADJ=0".
>>     #OOM_ADJ=-17
>>     ## STOP EDITING HERE
>>     # The path that is to be used for the script
>>     PATH=/usr/local/sbin:/usr/__local/bin:/sbin:/bin:/usr/__sbin:/usr/bin
>>     # What to use to start up the postmaster.  (If you want the script
>>     to wait
>>     # until the server has started, you could use "pg_ctl start -w" here.
>>     # But without -w, pg_ctl adds no value.)
>>     DAEMON="$prefix/bin/__postmaster"
>>     # What to use to shut down the postmaster
>>     PGCTL="$prefix/bin/pg_ctl"
>>     set -e
>>     # Only start if we can find the postmaster.
>>     test -x $DAEMON ||
>>              echo "$DAEMON not found"
>>              if [ "$1" = "stop" ]
>>              then exit 0
>>              else exit 5
>>              fi
>>     # Parse command line parameters.
>>     case $1 in
>>        start)
>>              echo -n "Starting PostgreSQL: "
>>              test x"$OOM_SCORE_ADJ" != x && echo "$OOM_SCORE_ADJ" >
>>              test x"$OOM_ADJ" != x && echo "$OOM_ADJ" > /proc/self/oom_adj
>>              echo "ok"
>>        stop)
>>              echo -n "Stopping PostgreSQL: "
>>              su - $PGUSER -c "$PGCTL stop -D '$PGDATA' -s -m fast"
>>              echo "ok"
>>        restart)
>>              echo -n "Restarting PostgreSQL: "
>>              su - $PGUSER -c "$PGCTL stop -D '$PGDATA' -s -m fast -w"
>>              echo "ok"
>>        reload)
>>              echo -n "Reload PostgreSQL: "
>>              su - $PGUSER -c "$PGCTL reload -D '$PGDATA' -s"
>>              echo "ok"
>>        status)
>>              su - $PGUSER -c "$PGCTL status -D '$PGDATA'"
>>              # Print help
>>              echo "Usage: $0 {start|stop|restart|reload|__status}" 1>&2
>>              exit 1
>>     esac
>>     exit 0
>>     -P.
>>     ******************************__******************************__**
>>     phurvitz at u.washington.edu <mailto:phurvitz at u.washington.edu> |
>>     http://gis.washington.edu/__phurvitz
>>     <http://gis.washington.edu/phurvitz>
>>     On 2/25/2015 12:25, Bborie Park wrote:
>>         Can you post the shell script?
>>         On Wed, Feb 25, 2015 at 11:50 AM, Phil Hurvitz <phurvitz at uw.edu
>>         <mailto:phurvitz at uw.edu <mailto:phurvitz at uw.edu>>> wrote:
>>              Thanks Bborie, I am starting with a shell script, and have
>>         added the
>>              env vars to that script, but am still unable to access the
>>         out-db
>>              rasters.
>>              -P.
>>         ******************************____**************************
>> **__**__**
>> UW-CBE
>> 354802
>> USA
>>         <mailto:phurvitz at u.washington.__edu
>>         <mailto:phurvitz at u.washington.edu>> |
>>         http://gis.washington.edu/____phurvitz
>>         <http://gis.washington.edu/__phurvitz>
>>         <http://gis.washington.edu/phurvitz>>
>> Saint-Exupéry
>> **__**__**
>>              On 2/25/2015 11:45, Bborie Park wrote:
>>                  The env variables need to be within the environment of
>>         the postgres
>>                  process. How are you starting postgres?
>>                  Shell script? Then you should be able to add the
>>         variables to
>>                  that script.
>>                  Direct invocation of posrgres on the command line? You
>>         need to
>>                  have the
>>                  variables before the command
>>                  VAR=1 postgres ...
>>                  -bborie
>>                  On Feb 25, 2015 11:40 AM, "Phil Hurvitz"
>>         <phurvitz at uw.edu <mailto:phurvitz at uw.edu>
>>         <mailto:phurvitz at uw.edu <mailto:phurvitz at uw.edu>>>> wrote:
>>                       Thanks Bborie, I built from the tarball rather
>>         than using
>>                  an rpm;
>>                       does that still mean I should be adding the
>>         environment
>>                  variables to
>>                       /etc/sysconfig/pgsql/______postgresql
>>                       So for overkill I added the env vars to that file
>>         as well
>>                  as to the
>>                       init script, restarted PostgreSQL, and it seems I
>>         still cannot
>>                       access the out-db raster.
>>                       I added a slope raster using:
>>                       I can get metadata (sorry for the ugly text
>> wrapping):
>>                       select rid, (foo.md <http://foo.md>
>>         <http://foo.md> <http://foo.md>).* from
>>                  (select rid,
>>                       st_Metadata(rast)  as md from slope) as foo;
>>                         rid |    upperleftx    |    upperlefty    |
>>         width | height |
>>                       scalex      |      scaley       | skewx | skewy |
>>         srid |
>>                  numbands
>>         -----+------------------+-----______-------------+-------+--
>> --__--__--__+------------------+--__----__----__---------+--
>> -----+__------__-+----__--+----------
>>                           1 | 835161.301005914 | 758483.868026069 |
>>         31935 |  34649 |
>>                       32.8083333333333 | -32.8083333333333 |     0 |
>>           0 | 2926
>>                  |        1
>>                       But cannot access values:
>>                       ERROR:  rt_raster_load_offline_data: Access to
>> offline
>>                  bands disabled
>>                       CONTEXT:  SQL function "st_summarystats" statement 1
>>                       select st_value(rast, 1, 1, 1) from slope;
>> offline
>>                  bands disabled
>>                       -P.
>>         ******************************______************************
>> **__**__**__**
>>         Professor | UW-CBE
>>         | Box 354802
>>         98195-4802, USA
>>         <mailto:phurvitz at u.washington.>____edu
>>         <mailto:phurvitz at u.washington.edu>>> |
>>         http://gis.washington.edu/______phurvitz
>>         <http://gis.washington.edu/____phurvitz>
>>         <http://gis.washington.edu/__phurvitz>>
>>         <http://gis.washington.edu/phurvitz>>>
>>         Saint-Exupéry
>> **__**__**__**
>>         <mailto:dustymugs at gmail.com>
>>         <mailto:dustymugs at gmail.com>> <mailto:dustymugs at gmail.com
>>                  <mailto:dustymugs at gmail.com <mailto:dustymugs at gmail.com
>>                           Wed Feb 25 10:46:59 PST 2015
>>                           Philip,
>>                           POSTGIS_ENABLE_OUTDB_RASTERS=1 is an environment
>>                  variable not to
>>                           be in
>>                           postgresql.conf.
>>                           The same is true for
>>                  POSTGIS_GDAL_ENABLED_DRIVERS=______ENABLE_ALL
>>         https://wiki.postgresql.org/______wiki/PostgreSQL_on_RedHat_
>> ______Linux
>>         <https://wiki.postgresql.org/____wiki/PostgreSQL_on_RedHat__
>> ___Linux>
>> ___Linux
>>         <https://wiki.postgresql.org/__wiki/PostgreSQL_on_RedHat___Linux
>> ___Linux
>>         <https://wiki.postgresql.org/__wiki/PostgreSQL_on_RedHat___Linux>
>>         <https://wiki.postgresql.org/wiki/PostgreSQL_on_RedHat_Linux>>>
>>                           Based upon the above, it looks like you should
>> add
>>                           to  /etc/sysconfig/pgsql/______postgresql
>>                           The above assumes you're using the packages
>>         provided by
>>                  PostgreSQL.
>>         http://www.postgresql.org/______download/linux/redhat/
>>         <http://www.postgresql.org/____download/linux/redhat/>
>>         <http://www.postgresql.org/__download/linux/redhat/>>
>>         <http://www.postgresql.org/download/linux/redhat/>>>
>>                           -bborie
>>                       On 2/25/2015 10:10, Phil Hurvitz wrote:
>>                           Hi all, I am having trouble starting PostGIS
>> with
>>                  out-db raster
>>                           support
>>                           In my
>>         /usr/local/pgsql/data/______postgresql.conf file I
>>                  include the
>>                           line
>>                           after which PostGIS won't start (service
>>         postgresql start).
>>                           Software is
>>                           postgis_full_version
>>         ------------------------------______------------------------
>> --__--__--__-----------
>>                              POSTGIS="2.1.3 r12547"
>>         GEOS="3.4.2-CAPI-1.8.2 r3921"
>>                           PROJ="Rel. 4.7.1,
>>                           23 September 2009" GDAL="GDAL 1.11.2, released
>>         2015/02/10"
>>                           LIBXML="2.7.6" TOPOLOGY RASTER
>>                           Also PostGIS won't start when I specify
>>                           Any help would be appreciated!
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20150225/b474c2a1/attachment.html>
