[postgis-users] TopologyException: geom is invalid
Rémi Cura remi.cura at gmail.com
Thu Feb 26 00:28:50 PST 2015
And also ST_IsSimple (that precisely check for self intersection).
Cheers,
Rémi-C
2015-02-26 8:32 GMT+01:00 BladeOfLight16 <bladeoflight16 at gmail.com>:
> On Wed, Feb 25, 2015 at 12:14 PM, Joseph Spenner <joseph85750 at yahoo.com>
> wrote:
>> DBD::Pg::st execute failed: ERROR:  Error performing intersection:
>> TopologyException: Input geom 1 is invalid: Self-intersection at or near
>> point -381688.06935935974 -1206669.4272876547 at -381688.06935935974
>> -1206669.4272876547 at ./test.pl line 151.
> Did you try ST_IsValid to verify the geometry is valid according to the
> OGC standard? (See
> http://postgis.net/docs/using_postgis_dbmanagement.html#OGC_Validity.
> ST_IsValidDetail and ST_IsValidReason are also helpful in this regard.)
> What happens if you run it through ST_MakeValid? Be aware that ST_MakeValid
> can sometimes result in GeometryCollections if the input shape is malformed
> (usually "rings" without enough points are that have different start and
> end points).
> postgis-users mailing list
> postgis-users at lists.osgeo.org
> http://lists.osgeo.org/cgi-bin/mailman/listinfo/postgis-users
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20150226/ba0eb27c/attachment.html>
