[postgis-users] Checking Road Network Topology
toni hernández toni at sigte.udg.edu
Tue Jan 27 02:39:05 PST 2015
No I don't see anything wrong with that.
cheers.
On 24/01/2015 00:57, Miller, Stephan wrote:
> Thanks.
> I have set up a new topo geometry in the “roads” table.  I am
> transforming the 4326 coordinates on-the-fly to 32648.
> Do you see anything wrong with reusing the roads table for the processing?
> Thanks,
> Steve
> *From:*postgis-users-bounces at lists.osgeo.org
> [mailto:postgis-users-bounces at lists.osgeo.org] *On Behalf Of *toni
> hernández
> *Sent:* Friday, January 23, 2015 2:52 AM
> *To:* postgis-users at lists.osgeo.org
> *Subject:* Re: [postgis-users] Checking Road Network Topology
> Steve,
> I transformed the geometries into a new table.
> >From there I created a new topology using the new reference system
> (25831)
> On 22/01/2015 16:35, Miller, Stephan wrote:
>     Thanks.
>     Here is the code as it now stands.  I was using 4326 and topology
>     will not work for geography coordinates.  Can you share your code
>     so that I can compare?  I am trying to do an on-the-fly transform
>     to 32648 for each record in the line 26.  Is that how you
>     approached this problem?
>     Thanks,
>     Steve
>     <mailto:postgis-users-bounces at lists.osgeo.org>
>     hernández
>     *Sent:* Thursday, January 22, 2015 10:14 AM
>     <mailto:postgis-users at lists.osgeo.org>
>     Steve,
>     I had the same issue when working with geometries using srid=4326
>     . I was also following the same link
>     (http://blog.mathieu-leplatre.info/use-postgis-topologies-to-clean-up-road-networks.html)
>     Then I tried with some projected geometries (units = meters) and
>     the problem was gone. I am not sure why. Maybe it was just a
>     coincidence.
>     cheers.
>     On 20/01/2015 20:45, Miller, Stephan wrote:
>         All –
>         I am attempting to validate the topology of a dense road
>         network ( 1.2 Million roads) modeled after
>         from July 2013
>         <http://blog.mathieu-leplatre.info/use-postgis-topologies-to-clean-up-road-networks.html%20from%20July%202013>.
>         The code is given below:
>         -- HC_RoadTopologicalCheck
>         -- Drop the existing topology
>         SELECT topology.DropTopology('roads_topo');
>         SELECT topology.CreateTopology('roads_topo',4326, 0.000001, true);
>         SELECT topology.AddTopoGeometryColumn('roads_topo', 'fgcm',
>         'transportationgroundcrv', 'topo_shape', 'LINESTRING');
>         --UPDATE transportationgroundcrv SET topo_shape =
>         topology.toTopoGeom(transportationgroundcrv.shape,
>         'roads_topo', 1, 1.0);
>         -- Encapsulate the UPDATE inside code that checks for errors
>         DO $$ DECLARE r record;
>         BEGIN
>             FOR r IN SELECT * FROM transportationgroundcrv loop
>                 BEGIN
>                     WHERE r.objectid = r.objectid;
>                 EXCEPTION
>                         WHEN OTHERS THEN
>                         RAISE WARNING 'Loading of record % failed: %',
>         r.objectid, SQLERRM;
>                 END;
>             END LOOP;
>         END$$;
>         Select * from ValidateTopology('roads_topo');
>         I am getting everything passing to the exception statement and
>         all the records are being flagged with
>         WARNING:  Loading of record 791456 failed: SQL/MM Spatial
>         exception - curve not simple
>         Intermittently, I am getting the following error also.
>         WARNING:  Loading of record 792591 failed: Spatial exception -
>         geometry intersects edge 69612
>         Everything appears to be flagged as an error; the
>         ValidateTopology call returns nothing.
>         Any insights or suggestions would be appreciated.
>         Steve
>         _______________________________________________
>         postgis-users mailing list
>         postgis-users at lists.osgeo.org  <mailto:postgis-users at lists.osgeo.org>
>         http://lists.osgeo.org/cgi-bin/mailman/listinfo/postgis-users
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20150127/664a6b15/attachment.html>
