[postgis-users] Get parallel some route.
Nicolas Ribot nicolas.ribot at gmail.com
Wed Jan 28 02:44:30 PST 2015
Hi Guillaume,
Not sure I understand what you want to achieve.
Can you describe it, maybe with an image. (or in french)
Non-simple lines can be cut at their intersection to make them simple.
Nicolas
On 28 January 2015 at 09:16, Guillaume ARNAUD <guillaume.arnaud at cg82.fr>
wrote:
>   Hello,
> We use Postgre / Postgis database with ArcGIS Server and Desktop 10.2. All
> our data are inserted with keyword Postgis into our database.
> The table that has the trouble is a route table with 292 linestring. I
> need these routes is not bunk. I try to use ST_OffsetCurve function to do
> this. I found on the help and on a ticket that we must have geometry which
> is simple. More than 250 isn't. Is there any solution to fix the problem or
> to bypass the problem .
> Thanks for your work.
> Greating.
> ARNAUD Guillaume
> Sorry for my poor english, I'm french.
> "PostgreSQL 9.2.2, compiled by Visual C++ build 1600, 64-bit
> POSTGIS="2.0.4" GEOS="3.4.2-CAPI-1.8.2 r0" PROJ="Rel. 4.8.0, 6 March
> 2012" GDAL="GDAL 1.10.0, released 2013/04/24" LIBXML="2.7.8"
> LIBJSON="UNKNOWN" (core procs from "2.0.4" need upgrade) RASTER (raster
> procs from "2.0.4" need upgrade)"
> OS : Windows Server Standard SP 2
> Guillaume ARNAUD
> Cellule SIGD
> Direction de l'Informatique
> Conseil Général de Tarn-et-Garonne
> 05-63-91-82-37
> En interne, utilisez le Click To Call : 8237
> <https://10.200.3.1:8443/webdialer/Webdialer?destination=8237>
> [image: test] <http://www.carto.cg82.fr/>
> postgis-users mailing list
> postgis-users at lists.osgeo.org
> http://lists.osgeo.org/cgi-bin/mailman/listinfo/postgis-users
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20150128/0ccef075/attachment.html>
Type: image/jpeg
Desc: not available
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20150128/0ccef075/attachment.jpg>
