[postgis-users] Extension upgrade has no update path 2.1.1 to 2.1.7
Moen, Paul T. pmoen at nd.gov
Mon Jul 20 13:25:04 PDT 2015
I am upgrading from postgis 2.1.1 to 2.1.7 using extensions.
After entering the following,
ALTER EXTENSION postgis UPDATE TO "2.1.7”;
I get error
ERROR:  extension "postgis" has no update path from version "2.1.1" to version "2.1.7"
********** Error **********
SQL state: 22023
The documentation says
If you get an error notice something like:
No migration path defined for ... to 2.1.9dev
Then you'll need to backup your database, create a fresh one as described in Section 2.6, “Creating a spatial database using EXTENSIONS”<http://postgis.net/docs/manual-2.1/postgis_installation.html#create_new_db_extensions> and then restore your backup ontop of this new database.
Is it typical to have no update path within 2.1.x versions?  How many versions typically have an upgrade path?  Am I wrong in saying that extensions have a worse upgradeability within 2.1.x versions as compared to not using the extensions or would the postgis_upgrade_21_minor.sql also fail going from 2.1.1 to 2.1.7.
Thanks for any insight,
Paul
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20150720/b3860de2/attachment.html>
