[postgis-users] WITH ...
franco base frenk.calza at gmail.com
Fri Jul 31 03:58:50 PDT 2015
It's ab SQL error
Try
WITH
positiu AS (
    SELECT rid, ST_Reclass(ST_Band(rast, 1), 1, '[1-10000]:1', '16BSI',
0) ad rast
    FROM rastertmp.prova
Il 31/lug/2015 12:44, "juli g. pausas" <juli.g.pausas at uv.es> ha scritto:
> Hi
> I'm slowly learning postgis ...
> I have these 3 SELECTS that works well when run independently, but I'm now
> trying to use them together in a WITH query, and I cannot make it run. What
> I'm doing wrong?
> WITH
> positiu AS (
>     SELECT rid, ST_Reclass(ST_Band(rast, 1), 1, '[1-10000]:1', '16BSI', 0)
> isok AS (SELECT t1.rid, ST_Union(ST_Intersection(t1.rast, 1, t2.rast, 1,
> 'BAND1'))
>     FROM rastertmp.prova AS t1, positiu AS t2
>     WHERE ST_Intersects(t1.rast, t2.rast)
>         GROUP BY t1.rid
> clips AS (
>     SELECT p.ecoregion_cod, ST_Union(ST_Clip(r.rast,1, p.geom, true)) AS
> rast
>     FROM gis_wd.wd_ecoregiones AS p, isok AS r
>     WHERE ST_Intersects(r.rast, p.geom)
>     GROUP BY ecoregion_cod
> SELECT ecoregion_cod, (ST_SummaryStats(rast, 1)).* FROM clips
> -- ERROR: column t2.rast does not exist
> In fact, I'm assuming that running these SELECTS in a single WITH query is
> more efficient (faster?) than running each one separately, generating
> intermediate tables (less disk access?). But perhaps I'm wrong, any idea?
> Thanks
> Juli
> *CIDE, CSIC*  |  www.uv.es/jgpausas  |
> postgis-users mailing list
> postgis-users at lists.osgeo.org
> http://lists.osgeo.org/cgi-bin/mailman/listinfo/postgis-users
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20150731/61ed0be0/attachment.html>
