[postgis-users] error adding data into ArcGIS
Mark Volz MarkVolz at co.lyon.mn.us
Mon Jun 8 14:29:34 PDT 2015
Hello,
All the sudden I am getting an error loading data into ArcGIS:  "One or more layers failed to draw:  lyongis.public.parcels:  The specified coordinate exceeds the valid coordinate range"
The script (below) that I used in the past always had worked fine.  So I am not sure where to begin.  QGIS works fine.  I am using ArcGIS 10.3 with Postgres 9.2
Sincerely,
Mark Volz, GISP
Lyon County GIS Coordinator
Script to load data into PostGIS.
set PATH=C:\Program Files\PostgreSQL\9.2\bin;%PATH%
cd /d "D:\PostGISIncoming\LyonGIS"
rem load data to postgis
for %%f in (*.shp) do shp2pgsql -d -I -s 103749 -W LATIN1 %%f %%~nf | psql -w -U postgres -d lyongis
for %%a in (*.*) do move "%%a" "D:\PostGISIncoming\LyonGIS\Done"
cd /d "D:\PostGISIncoming"
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20150608/cf0947b4/attachment.html>
