[postgis-users] Distance between two furthest points of a group
Nick Ves vesnikos at gmail.com
Fri Jun 26 13:06:51 PDT 2015
You can cross join to create the cartesian product of them and use it to
calculate the distance of each with regards to the other:
select a.id,b.id, st_distance(a.geom,b.geom) d from points a cross join
points b order by d desc limit 1;
ofc that will take forever because it will have to create an m x n table
(800 secs and counting...)
As I see it the two points with the furthest distance between them should
touch the borders of you datasets convexhull. So you can filter out those
inside the boundaries and do the calculations with  the remaining points
along the borders :
with f as
select a.geom,a.id from
points foo,
(select ST_ExteriorRing (st_convexhull(st_collect(geom))) geom from points)
bar
where st_Dwithin(foo.geom,bar.geom,0.00000001)
select a.id,b.id, st_distance(a.geom,b.geom) d from f  a cross join f b
​should give you the id of your targets and the distance between them​
On Fri, Jun 26, 2015 at 2:54 PM, Jonathan Moules <J.Moules at hrwallingford.com
> wrote:
>  Hi List,
> I have sets of points (up to 250,000 in a set) and I want to get the
> furthest distance between any of them.
> In theory the simplest way is to use
> ST_MinimumBoundingCircle(ST_Collect(geography) and then get the diameter of
> that.
> The problem is – I don’t seem to be able to get the diameter of that
> circle (which would give me the distance I want).
> Does anyone have any thoughts on this? Is there a good way to get the
> diameter? Or some other way of getting the distance I desire.
> Thanks,
> Jonathan
> *HR Wallingford and its subsidiaries* uses faxes and emails for
> confidential and legally privileged business communications. They do not of
> themselves create legal commitments. Disclosure to parties other than
> addressees requires our specific consent. We are not liable for
> unauthorised disclosures nor reliance upon them.
> If you have received this message in error please advise us immediately
> and destroy all copies of it.
> HR Wallingford Limited
> Howbery Park, Wallingford, Oxfordshire, OX10 8BA, United Kingdom
> Registered in England No. 02562099
> postgis-users mailing list
> postgis-users at lists.osgeo.org
> http://lists.osgeo.org/cgi-bin/mailman/listinfo/postgis-users
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20150626/f317f553/attachment.html>
