[postgis-users] Fw: Mapserver displays an empty map using layer from postgis
Ronald Muchini ronaldmuchini at yahoo.com
Fri Mar 6 00:04:21 PST 2015
--- On Fri, 3/6/15, Ronald Muchini <ronaldmuchini at yahoo.com> wrote:
> From: Ronald Muchini <ronaldmuchini at yahoo.com>
> Subject: Mapserver displays an empty map using layer from postgis
> To: "ms4w_users" <ms4w-users at lists.maptools.org>
> Cc: "ms4w_users" <ms4w-users at lists.maptools.org>
> Date: Friday, March 6, 2015, 12:02 AM
> I have a raster layer in postgis,
> which I'm trying to display it in the browser using the
> following code. My Postgis is Installed in the directory,
> "C:\Program Files(x86)\PostgreSQL\9.3\bin" and mapsever
> directory is "C:\ms4w".
> MAP
> NAME "Lakes"
> IMAGECOLOR 255 255 255
> SIZE 600 800
> IMAGETYPE PNG24
> PROJECTION
>     "init=epsg:4326"
> END
> EXTENT -17.9334 30.5019 -17.7303 30.8789
> WEB
>     METADATA
>         "ows_enable_request"
>         "map"
> "C:/ms4w/apps/Lakes/configpg.map"
>         "ows_schemas_location"
> "http://schemas.opengeospatial.net"
>         "ows_title"
> "LakesWMS"
>         "ows_onlineresource"
> "http://localhost/cgi-bin/mapserv.exe?map=C:/ms4w/apps/Lakes/configpg.map&"
>         "ows_srs" "EPSG:4326 "
> #latlon
> "wms_feature_info_mime_type" "text/plain"
> "wms_feature_info_mime_type" "text/html"
>         "wms_server_version"
> "1.3.0"
>         "wms_formatlist"
> "image/png,image/gif,image/jpeg"
>         "wms_format"
> "image/png"
>     END #metadata
> END #web
> LAYER
>     NAME "ras"
>     TYPE RASTER
>     STATUS ON
>     CONNECTIONTYPE postgis
>     CONNECTION "user=postgres password=magodo
> dbname=wqm host=localhost port=5432 options='-c
> client_encoding=UTF8'"
>     DATA "geometry FROM testras9 USING UNIQUE
> id USING srid=4326"
>     METADATA
>         "ows_title" "ras"
>         "ows_extent" "
> -17.9334 30.5019 -17.7303 30.8789"
>     END #metadata
>     PROJECTION
>         "init=epsg:4326"
>     END
>     CLASS
>         NAME "ras"
>         OUTLINECOLOR 255 255
> 255
>         COLOR 137 205 102
>     END #class ras
> END #layer ras
> END #map
> Im calling the webpage using the url below:
> "http://localhost/cgi-bin/mapserv.exe?map=C:/ms4w/apps/Lakes/config.map&SERVICE=WMS&VERSION=1.3.0&REQUEST=GetMap&LAYERS=ras&STYLES=&CRS=EPSG:4326&BBOX=5,97,21,106&WIDTH=600&HEIGHT=800&FORMAT=image/png"
> No errors pop up but the browser displays an empty map
> space.
> How can I resolve this issue
> Thanks in advance
