[postgis-users] postgis-jdbc-2.1.5.jar
Mason, Matthew MATTHEW.S.MASON at saic.com
Thu Mar 12 07:25:36 PDT 2015
On Wed, 11 Mar 2015 16:22:00 +0100, Santilli, Sandro wrote:
>On Wed, Mar 11, 2015 at 03:11:13PM +0000, Mason, Matthew wrote:
>> When compiling the postgis jdbc jar (i.e. postgis-jdbc-2.1.3.jar) from
>> source the maven pom file has the version as 2.1.4dev by default in
>> the postgis2.1.5 source.
>Sounds like a bug.
>Version of pom.xml is parametrized in 2.0 branch:
>    <artifactId>postgis-jdbc</artifactId>
>    <version>${POSTGIS_MAJOR_VERSION}.${POSTGIS_MINOR_VERSION}.${POSTGIS_MICRO_VERSION}</version>
>But is hard-coded in 2.1 branch:
>    <version>2.1.4dev</version>
>And in master:
>    <version>2.2.0dev</version>
>The build.xml file still uses parameters:
>  <property file="${versioninfo}"/>
>  <property name="postgis_version" value="${POSTGIS_MAJOR_VERSION}.${POSTGIS_MINOR_VERSION}.${POSTGIS_MICRO_VERSION}"/>
>It looks like switching to hard-coded was intentional, here:
>http://trac.osgeo.org/postgis/ticket/2626
>You may want to add yourself in Cc there, and ping the java guys (I'm enough of an hater)
>--strk;
Thanks!  I thought this might be the case.
Matt
