[postgis-users] Queries on partitioned table not behaving as expected
Bborie Park dustymugs at gmail.com
Mon Nov 2 09:28:44 PST 2015
That check constraint is not going to help you as it is too complicated for
the partitioning task. I don't believe the partitioning constraint can be
functional but needs to be simpler and built upon a basic data type...
Something like...
CREATE TABLE max_extent AS (
  id integer PRIMARY KEY,
  geom geometry(POLYGON)
And then the parent/partition tables had a reference to pc_extent...
CREATE TABLE ahn3_pointcloud.ahn3_all
  id integer NOT NULL,
  pa pcpatch(7),
  max_extent_id integer
Then your queries become...
WITH max_extents AS (
SELECT
  id
FROM max_extent
WHERE PC_Intersects(geom, ST_MakeEnvelope(120740,486076,121074,486292,
28992))
SELECT
FROM ahn3_all
JOIN max_extents
  ON ahn3_all.max_extent_id = max_extents.id
-bborie
On Mon, Nov 2, 2015 at 8:45 AM, Rubio Vaughan <rubio.vaughan at geodan.nl>
wrote:
> Dear all,
> We are trying to load a large LIDAR pointcloud dataset into multiple
> tables in PostGIS, using the point cloud extension. Eventually the whole
> data set will consist of 1400+ tables, containing about 1 million records
> each. Using a union view on all these tables would result in terrible
> performance, which is why we are trying to optimize query performance using
> partitioned tables. According to the documentation, the use of partitioned
> tables with CHECK constraints should cause the query planner to only scan
> those tables for which the CHECK constraint matches. Excerpt from the
> documentation:
> *18.7.4. Other Planner Options*
> constraint_exclusion (enum): Controls the query planner's use of table
> constraints to optimize queries. The allowed values of constraint_exclusion
> are on (examine constraints for all tables), off (never examine
> constraints), and partition (examine constraints only for inheritance child
> tables and UNION ALL subqueries). partition is the default setting. It is
> often used with inheritance and partitioned tables to improve performance.
> When this parameter allows it for a particular table, the planner compares
> query conditions with the table's CHECK constraints, and omits scanning
> tables for which the conditions contradict the constraints.
> However, as you can see from the example query below, the indexes for all
> child tables are still scanned. I would expect the query planner to only
> scan table c_25gn1, which contains the queried region. Does anyone here
> have experience with partitioned tables? I would be delighted to get some
> pointers for figuring out this problem.
> Thanks in advance for any help!
> Best regards,
> Rubio Vaughan
> *General info:*
> SELECT postgis_full_version();
> "POSTGIS="2.2.0 r14208" GEOS="3.5.0-CAPI-1.9.0 r4084" SFCGAL="1.2.0"
> PROJ="Rel. 4.8.0, 6 March 2012" GDAL="GDAL 2.0.1, released 2015/09/15"
> LIBXML="2.9.1" LIBJSON="0.11.99" TOPOLOGY (topology procs from "2.1.4
> r12966" need upgrade) RASTER"
> SHOW "constraint_exclusion";
> "partition"
> *The parent table:*
>   pa pcpatch(7)
> *One of the child tables:*
> CREATE TABLE ahn3_pointcloud.c_25dn2
>   id serial NOT NULL,
>   pa pcpatch(7),
>   CONSTRAINT c_25dn2_pkey PRIMARY KEY (id),
>   CONSTRAINT check_extent CHECK (pc_intersects(pa,
> st_geomfromtext('POLYGON((115000 487500,120000 487500,120000 481250,115000
> 481250,115000 487500))'::text, 28992)))
> INHERITS (ahn3_pointcloud.ahn3_all)
> *Example query:*
> EXPLAIN SELECT COUNT(pa) FROM ahn3_pointcloud.ahn3_all
> WHERE PC_Intersects(pa, ST_MakeEnvelope(120740,486076,121074,486292,
> 28992))
> "Aggregate  (cost=301989.36..301989.37 rows=1 width=32)"
> "  ->  Append  (cost=0.00..301248.82 rows=296216 width=32)"
> "        ->  Seq Scan on ahn3_all  (cost=0.00..0.00 rows=1 width=32)"
> "              Filter:
> (('010300002040710000010000000500000000000000407AFD4000000000<snip>
> "        ->  Bitmap Heap Scan on c_25gn1  (cost=6064.85..59546.09
> rows=58574 width=32)"
> "              Recheck Cond:
> ('010300002040710000010000000500000000000000407AFD40000<snip>
> "              Filter:
> _st_intersects('010300002040710000010000000500000000000000407<snip>
> "              ->  Bitmap Index Scan on c_25gn1_idx  (cost=0.00..6050.20
> rows=175722 width=0)"
> "                    Index Cond:
> ('010300002040710000010000000500000000000000407AFD4<snip>
> "        ->  Bitmap Heap Scan on c_30fz1  (cost=7990.39..77907.99
> rows=76576 width=32)"
> "              Recheck Cond:
> "              Filter:
> "              ->  Bitmap Index Scan on c_30fz1_idx  (cost=0.00..7971.24
> rows=229727 width=0)"
> "                    Index Cond:
> "        ->  Bitmap Heap Scan on c_30fz2  (cost=7393.57..71499.52
> rows=70210 width=32)"
> "              Recheck Cond:
> "              Filter:
> "              ->  Bitmap Index Scan on c_30fz2_idx  (cost=0.00..7376.02
> rows=210631 width=0)"
> "                    Index Cond:
> "        ->  Bitmap Heap Scan on c_25ez1  (cost=2624.69..26079.63
> rows=25688 width=32)"
> "              Recheck Cond:
> "              Filter:
> "              ->  Bitmap Index Scan on c_25ez1_idx  (cost=0.00..2618.27
> rows=77064 width=0)"
> "                    Index Cond:
> "        ->  Bitmap Heap Scan on c_25dn2  (cost=6714.83..66215.58
> rows=65167 width=32)"
> "              Recheck Cond:
> "              Filter:
> "              ->  Bitmap Index Scan on c_25dn2_idx  (cost=0.00..6698.54
> rows=195500 width=0)"
> "                    Index Cond:
> postgis-users mailing list
> postgis-users at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/postgis-users
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20151102/9e781cbd/attachment.html>
