[postgis-users] Running PostGIS from Eclipse
Greg Troxel gdt at ir.bbn.com
Thu Nov 5 13:30:15 PST 2015
Ruby Tahboub <ruby.tahboub at gmail.com> writes:
> I need help with configuring PostGIS to run from Eclipse. I already have
> Postgres/PostGIS installed, and I can run Postgres from Eclipse.
> When I type a query with a spatial predicate, I get the following error
> from parser:
> ERROR:  could not access file "$libdir/postgis-2.2": No such file or
> directory
What happens when you use the psql command line and run a query?
If that doesn't work ok, you'll have to fix that before worrying about
eclipse.  From the error, I suspect this isn't an eclipse issue.
Desc: not available
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20151105/2c4897c5/attachment.sig>
