[postgis-users] Running PostGIS from Eclipse
Ruby Tahboub ruby.tahboub at gmail.com
Thu Nov 5 14:33:02 PST 2015
I can run Postgres/ PostGIS from command line. No, I'm not using plugins, I
use eclipse to debug the backend code, it works for Postgresql queries but
it gives error for anything spatial. I suspect it's an eclipse
configuration.
On Thu, Nov 5, 2015 at 4:41 PM, Sylvain Racine <sracine at igreffe.net> wrote:
> Hi Ruby,
> Do you talk about compiling PostGIS in C++ with Eclipse or to access
> PostgreSQL DB with a SQL plugin in Eclipse? If yes, please indicate the
> name of your plugin.
> Regards
> Sylvain Racine
> ----------------original message-----------------
> De: "Ruby Tahboub" ruby.tahboub at gmail.com
> A: postgis-users at lists.osgeo.org
> Date: Thu, 5 Nov 2015 15:15:31 -0500
> > Dear All,
> > I need help with configuring PostGIS to run from Eclipse. I already have
> > Postgres/PostGIS installed, and I can run Postgres from Eclipse.
> > When I type a query with a spatial predicate, I get the following error
> > from parser:
> > ERROR: could not access file "$libdir/postgis-2.2": No such file or
> > directory
> > Thanks!
> > Ruby
> __________________________________________________
> > postgis-users mailing list
> > http://lists.osgeo.org/mailman/listinfo/postgis-users
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20151105/551be9a8/attachment.html>
