[postgis-users] (no subject)
Ruby Tahboub ruby.tahboub at gmail.com
Sun Nov 15 11:46:54 PST 2015
Hi Paul,
I did enable debugging in my postgres: *./configure
--prefix=/usr/local/pgsql2/ CFLAGS="-g -O0" --enable-debug *
The only issue the debugger does not step into anything defined inside
(postgis/gserialized_gist_2d.c
or postgis/gserialized_gist_nd.c) but it steps into other locations. What
do you think?
Here's an example:
*SELECT ST_Intersects(ST_GeographyFromText('SRID=4326;LINESTRING(-43.23456
72.4567,-43.23456 72.4568)'),
ST_GeographyFromText('SRID=4326;POINT(-43.23456 72.4567772)'))*
I placed a breakpoint inside *postgres* in:
*/src/backend/executor/execQual.c* inside function:
*ExecMakeFunctionResultNoSets* in Line:
*result = FunctionCallInvoke(fcinfo);* // as you already know, this is the
postgres macro which invokes functions as the ones defined inside postgis
The debugger nicely stepped into *postgis/geography_inout.c* function:
*geography_from_text* but NOT *gserialized_overlaps* defined inside
*postgis/**gserialized_overlaps_nd*
Thanks,
Ruby
On Sun, Nov 15, 2015 at 11:36 AM, Paul Ramsey <pramsey at cleverelephant.ca>
wrote:
> In addition to building your postgis with debugging (as you have done)
> you need to build your postgresql with debugging on, because the
> ./postgis directory inherits its build configuration from the
> postgresql sources (thanks to pgxs, a mixed blessing). So go back and
> rebuild your postgresql too.
> ATB,
> P
> On Sat, Nov 14, 2015 at 2:30 PM, Ruby Tahboub <ruby.tahboub at gmail.com>
> wrote:
> > Dear PostGIS-Users,
> > I'm debugging the sources of PostGIS (using Eclipse) for the purpose of
> > understanding how spatial predicates work and how to go about adding new
> > ones. I noticed that I can't step into postgis/gserialized_gist_2d.c,
> other
> > locations under the same directory e.g., postgis/geography_measurements.c
> > can step into nicely. Could you double check my configurations:
> > CFLAGS="-g3 -O0" ./configure
> --with-pgconfig=/usr/local/pgsql2/bin/pg_config
> > --with-projdir=/usr/local --enable-debug
> > postgis-2.2.0dev
> > Thanks,
> > Ruby
> > postgis-users mailing list
> > postgis-users at lists.osgeo.org
> > http://lists.osgeo.org/mailman/listinfo/postgis-users
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20151115/5a5ece76/attachment.html>
