[postgis-users] Error with ST functions
Paragon Corporation lr at pcorp.us
Fri Nov 20 21:21:29 PST 2015
Lorenzo,
There is nothing wrong here except your query.
There is no such signature as ST_Clip(Boolean, geom,rast)
It's
ST_Clip(geom,rast, boolean)
Your proc query did the array agg of protos out of sequence.
Easiest way to see this is just open a psql console and run
\df st_clip
And you should see this though your schema location is probably different from mine.
        List of functions
Schema  |  Name   | Result data type |                                                          Argument data types                                                          |  Type
postgis | st_clip | raster           | rast raster, geom geometry, crop boolean        | normal
postgis | st_clip | raster           | rast raster, geom geometry, nodataval double precision, crop boolean DEFAULT true                                                     | normal
postgis | st_clip | raster           | rast raster, geom geometry, nodataval double precision[] DEFAULT NULL::double precision[], crop boolean DEFAULT true                  | normal
postgis | st_clip | raster           | rast raster, nband integer, geom geometry, crop boolean        | normal
postgis | st_clip | raster           | rast raster, nband integer, geom geometry, nodataval double precision, crop boolean DEFAULT true                                      | normal
postgis | st_clip | raster           | rast raster, nband integer[], geom geometry, nodataval double precision[] DEFAULT NULL::double precision[], crop boolean DEFAULT true | normal
(6 rows)
Or look at the manual
http://postgis.net/docs/RT_ST_Clip.html
Hope that helps,
Regina
http://www.postgis.us
http://postgis.net
From: postgis-users [mailto:postgis-users-bounces at lists.osgeo.org] On Behalf Of Lorenzo Bottaccioli
Sent: Friday, November 20, 2015 7:10 AM
To: Lorenzo Bottaccioli <lorenzo.bottaccioli at gmail.com>; PostGIS Users Discussion <postgis-users at lists.osgeo.org>
Subject: Re: [postgis-users] Error with ST functions
HI, I'have tried to reinstall postgis. But i still get errors like this one:
 SELECT
ST_clip(True,polygon.geom, raster.rast)
FROM
  public.edifici as polygon,
  public.ele1000x1000 as raster;
ERROR:  function st_clip(boolean, geometry, raster) does not exist
LINE 2: ST_clip(True,polygon.geom, raster.rast)
HINT:  No function matches the given name and argument types. You might need to add explicit type casts.
gis=# SELECT
  n.nspname, p.proname, array_agg(t.typname)
 FROM
  pg_proc p, pg_namespace n, pg_type t
 WHERE p.proname = 'st_clip'
   AND n.oid = p.pronamespace
   AND t.oid = any (p.proargtypes)
 GROUP BY
   n.nspname, p.proname, p.oid;
 nspname | proname |              array_agg
 public  | st_clip | {bool,_float8,geometry,raster}
 public  | st_clip | {bool,_int4,_float8,geometry,raster}
 public  | st_clip | {bool,float8,geometry,raster}
 public  | st_clip | {bool,int4,float8,geometry,raster}
 public  | st_clip | {bool,int4,geometry,raster}
 public  | st_clip | {bool,geometry,raster}
2015-11-19 18:38 GMT+01:00 Sandro Santilli <strk at keybit.net <mailto:strk at keybit.net> >:
On Thu, Nov 19, 2015 at 06:25:46PM +0100, Lorenzo Bottaccioli wrote:
> grep -i st_bandisnodata rtpostgis.sql
> CREATE OR REPLACE FUNCTION st_bandisnodata(rast raster, band integer
> DEFAULT 1, forceChecking boolean DEFAULT FALSE)
> CREATE OR REPLACE FUNCTION st_bandisnodata(rast raster, forceChecking
> boolean)
>     AS $$ SELECT st_bandisnodata($1, 1, $2) $$
Right, so someone tempered with the db.
There might be more things missing.
One way to check what else is missing would be:
 BEGIN;
 CREATE EXTENSION postgis VERSION '2.1.2' FROM 'unpackaged';
 -- you'd get an error here, if anything is missing
 ROLLBACK; -- we're just checking, right?
Let me know if you need help with fixing things.
--strk;
  ()   Free GIS & Flash consultant/developer
  /\   http://strk.keybit.net/services.html
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20151121/f5708ebf/attachment.html>
