[postgis-users] Help with SQL query?
Pierre Racine Pierre.Racine at sbf.ulaval.ca
Mon Nov 23 08:16:52 PST 2015
Darrel,
1)      Create a new raster selecting the right pixels with ST_MapAlgebra(raster, raster)
2)      Make sure only intersecting rasters are processed by using their upper left corner X and Y coordinates (with ST_UpperLeftX() and UpperLeftY())
3)      Sum the selected pixels with ST_SummaryStats(rast)
All in all a global query should look like this:
SELECT (ST_SummaryStats(ST_Union(rast))).sum sum
FFOM (SELECT ST_MapAlgebra(tableA.rast, tableB.rast, 'IF [rast2] > threshold THEN [rast1] ELSE NULL ENDIF ' )
            FROM tableA, tableB
            WHERE ST_UpperleftX(tableA.rast) = ST_UpperleftX(tableB.rast) AND
                         ST_UpperleftY(tableA.rast) = ST_UpperleftY(tableB.rast) AND
                         maybe some other condition here if you get time series e.g. tableA.year = tableB.year AND tableA.month = tableB.month) foo
If you have millions of tile you could create indexes on ST_UpperleftX(tableA.rast), ST_UpperleftX(tableB.rast), ST_UpperleftY(tableA.rast) and ST_UpperleftY(tableB.rast) to make the query faster.
You could also just use WHERE ST_Intersects(tableA.rast, tableB.rast) instead...
Pierre
From: postgis-users [mailto:postgis-users-bounces at lists.osgeo.org] On Behalf Of Darrel Maddy
Sent: Monday, November 23, 2015 7:20 AM
To: PostGIS Users Discussion
Subject: [postgis-users] Help with SQL query?
Dear all,
As you know I am relatively new to postgis and SQL and therefore  I have much to learn. However, I am facing a paper deadline and need to do some quick analysis of the data I have and I am struggling to figure out how best to pursue what I need to do.
I have a significant number of rasters which have double precision values.  Without going into detail about what the rasters represent, I need to extract and sum values from one set of rasters in say table A based upon  values in another set of rasters in say table B  where the pixel value in the raster from Table B exceeds a threshold. Both tables are the same size (rasters are tiled) but I also need to figure out how I make sure the correct rasters are compared.  They have filenames like this rastervariable_10.tif, rastervariable_100.tif , presumably I need to use a logical expression to strip the numerical value (in this case this represents the year) and then order on that basis?
I can do this in QGIS one at a time but that is a little clumsy and rather time consuming.
If someone can just point me in the right direction I am sure I can figure out the rest for myself.
Apologies once more for asking what is probably a rather trivial question and yet again demonstrating my ignorance.
Many thanks
Darrel
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20151123/9f94a38b/attachment.html>
