[postgis-users] min distance to right and left
toni hernández toni at sigte.udg.edu
Mon Nov 23 23:48:10 PST 2015
I'll first approach it with topology. Sounds great! :)
(Also I hadn't thought about dead end streets.)
Thank you!
*Toni Hernández Vallès*
Servei de Sistemes d'Informació Geogràfica i Teledetecció
Universitat de Girona
*SIGTE*
Pl. Ferrater Mora 1
17071 Girona
Tel +34 972 418 039 (7026 intern)
toni at sigte.udg.edu <mailto:toni at sigte.udg.edu>
http://www.sigte.udg.edu
Twitter http://twitter.com/SIGTE_UDG
On 23/11/2015 21:59, Martijn Meijers wrote:
> Hi,
> Would http://postgis.net/docs/ST_ShortestLine.html help you in this case?
> I am not sure how important the distinction between left/right is, but
> are you sure that this is always defined properly just by looking at
> the street and building only? E.g. if you have the following: the
> house (in the center) is it on the left or right of the small dead end
> street?
> One option: You could build explicit topology and then use information
> of the faces and use left/right pointers on the edges (the streets) to
> determine that a building is on the left/right of a street (road part)
> - you can then also easily filter dead ends.
> Another (potentially less accurate) option: calculate orient2d
> (https://www.cs.cmu.edu/~quake/robust.html) for every segment of the
> street to every polygon vertex of the building (or even coarser
> approximation, but much faster: use centroid of the house and one
> segment that represents the street, e.g. vector from begin point
> segment - end point segment). I think you have to make such an
> orientation test in Postgres/PostGIS yourself by making a custom
> database function. Note that this could give wrong results when
> streets run around buildings (flipping of left/right as result).
> Martijn
> On 23-11-15 16:13, toni hernández wrote:
>> Hello everyone,
>> I have two tables: streets and buildings.
>> streets with a linestring geometry and buildings with polygons geometry.
>> I need to know what is the minimal distance from each street to a
>> building on the right, and then, what is the minimal distance from
>> the street to a building on the left.
>> Any ideas on how I should approach this?
>> Thank you!
>> *SIGTE*
>> Pl. Ferrater Mora 1
>> 17071 Girona
>> postgis-users mailing list
>> postgis-users at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/postgis-users
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20151124/72cba51b/attachment.html>
