[postgis-users] ERROR: WKB structure does not match expected size!
Francisco Salas Rosette fsalas at pinar.geocuba.cu
Fri Nov 27 09:22:29 PST 2015
When I try to restore my database ocurr this problems
pg_restore: [archiver (db)] Error while PROCESSING TOC:
pg_restore: [archiver (db)] Error from TOC entry 3737; 0 18356 TABLE DATA
test postgres
pg_restore: [archiver (db)] COPY failed for table "test": ERROR:  WKB
CONTEXT:  COPY test, line 238554, column the_geom:
"01050000A0AB1000000100000001020000801501000040087021D9B853C0AEF7080BA019364
000000000000000006508A39F..."
pg_restore: executing SEQUENCE SET test_gid_seq
I have PostgreSQL 9.2.4.1 y Postgis 2.1.0
Thanks & Regards
Francisco Salas
Anuncie sus servicios en ANDARIEGO� aplicaci�n para celulares sobre mapas de toda Cuba.
Visite el sitio http://andariego.geocuba.cu o http://www.andariego.cu, cont�ctenos por el correo andariego at geosi.geocuba.cu o por el tel�fono 8817400.
Ponga su informaci�n al servicio de todos.
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20151127/e0e6ef84/attachment.html>
