[postgis-users] $libdir/postgis-2.1: No such file or directory
Rémi Cura remi.cura at gmail.com
Tue Sep 15 00:52:36 PDT 2015
Hey,
have you check that the postgis-2.1.so file exists somewhere beside the
compile folder?
(captain obvious) you may need to restart the postgres server
(captain obvious) Need admin right when installing postgis, after compile.
If you compile yourself, some use of the command  `ldconfig`
at the right time may save you.
Cheers,
Rémi-C
2015-09-14 23:53 GMT+02:00 Devrim Gündüz <devrim at gunduz.org>:
> Hi,
> Are you compiling from source? If so, add --enable-raster for extension
> support.
> Or better, use RPMs: http://yum.postgreql.org .
> Regards,
> On September 15, 2015 12:17:38 AM GMT+03:00, Steve <sdcvass at gmail.com>
> wrote:
>> All,
>> Ive been beating this to death for too long and hope someone can steer me strait.
>> Freah install of Linux 6.6
>> Postgresql fresh install 9.3.9
>> On a closed network but I mined  (I think) all the rpm's I need for postgis.
>> Postgis install nicely but upon create extension, I get $libdir/postgis-2.1: No such file or directory
>> when running ./pg_config --pkglibdir, I see /var/lib/pgsql/9.3/lib.  postgis-2.1 is not there so I copy it there.  No matter what, I still get this error.
>> Any help for an old Oracle guy would be appreciated.
>> Steve
>> Sent from my iPhone
>> postgis-users mailing list
>> postgis-users at lists.osgeo.org
>> http://lists.osgeo.org/cgi-bin/mailman/listinfo/postgis-users
> Sent from my Android device with K-9 Mail. Please excuse my brevity.
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20150915/6828984a/attachment.html>
