[postgis-users] postgis-users Digest, Vol 163, Issue 11
Birgit Laggner birgit.laggner at ti.bund.de
Mon Sep 28 01:02:17 PDT 2015
Hi Bob,
now, I understand your problem. My suggestion would be to triple the
single quotation marks as in the small example below:
declare @v;
set @v = '''1''';
print @v;
I hope this works with your pgscript somehow...
Regards,
Birgit
Am 25.09.2015 um 14:19 schrieb Bistrais, Bob:
> Hi Birgit and David,
> Many thanks for your replies.  I actually tried what you had suggested.  Quoting the variable as '@myvariable' caused the liteal string, @myvariable, to be passed.  I also tried casting, but the variable still got passed as an integer, without quots, causing an error.
> In order to make it work, I created another field which is an integer field.  I populated the new field with the appropriate integer values.  This worked, but I would still be interested in finding a way to pas numeric characters as text.
> ________________________________________
> From: postgis-users-bounces at lists.osgeo.org [postgis-users-bounces at lists.osgeo.org] on behalf of postgis-users-request at lists.osgeo.org [postgis-users-request at lists.osgeo.org]
> Sent: Thursday, September 24, 2015 3:00 PM
> To: postgis-users at lists.osgeo.org
> Subject: postgis-users Digest, Vol 163, Issue 11
> Send postgis-users mailing list submissions to
> To subscribe or unsubscribe via the World Wide Web, visit
>          http://lists.osgeo.org/cgi-bin/mailman/listinfo/postgis-users
> or, via email, send a message with subject or body 'help' to
> You can reach the person managing the list at
>          postgis-users-owner at lists.osgeo.org
> When replying, please edit your Subject line so it is more specific
> than "Re: Contents of postgis-users digest..."
> Today's Topics:
>     1. Using string variables with PGScript (Bistrais, Bob)
>     2. Re: Using string variables with PGScript (David Fawcett)
>     3. Re: Using string variables with PGScript (Birgit Laggner)
> Message: 1
> Date: Wed, 23 Sep 2015 21:26:32 +0000
> From: "Bistrais, Bob" <Bob.Bistrais at maine.gov>
> To: "postgis-users at lists.osgeo.org" <postgis-users at lists.osgeo.org>
> Subject: [postgis-users] Using string variables with PGScript
> Message-ID:
>          <D655A37D8BC306438F87579A672E3D107AEE9906 at OIT-TEAQEXMBX01.som.w2k.state.me.us>
> Content-Type: text/plain; charset="us-ascii"
> I am having trouble using a variable in a Select statement, using PGScript.  I am trying to define a string variable, then use it in the Select statement.  Something like this:
> DECLARE @MYSTRING;
> SET @MYSTRING = CAST(@REC[0]['mycode'] AS STRING);   -- at REC was set from a previous select
> SELECT * from mytable where myfield = @MYSTRING;
> -The variable is not quoted, so the select statement fails.  How do I get the string variable to be enclosed in quotes?
> -------------- next part --------------
> An HTML attachment was scrubbed...
> URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20150923/43f67cbd/attachment-0001.html>
> Message: 2
> Date: Wed, 23 Sep 2015 20:43:30 -0500
> From: David Fawcett <david.fawcett at gmail.com>
> To: PostGIS Users Discussion <postgis-users at lists.osgeo.org>
> Subject: Re: [postgis-users] Using string variables with PGScript
> Message-ID:
>          <CAF7K3b8x=jEBPMWTa_B4hUOSNK=45tE0nM1xcjyS9wWRmoUodQ at mail.gmail.com>
> Content-Type: text/plain; charset="utf-8"
> Bob,
> I haven't ever used PGScript, but I wonder one of the postgres quote
> functions found on this page might work:
> http://www.postgresql.org/docs/9.1/static/functions-string.html
> I would try quote_literal()
> David.
> On Wed, Sep 23, 2015 at 4:26 PM, Bistrais, Bob <Bob.Bistrais at maine.gov>
>> DECLARE @MYSTRING;
>> previous select
> URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20150923/a0ce2539/attachment-0001.html>
> Message: 3
> Date: Thu, 24 Sep 2015 15:22:42 +0200
> From: Birgit Laggner <birgit.laggner at ti.bund.de>
> Message-ID: <5603F922.4090801 at ti.bund.de>
> Content-Type: text/plain; charset="windows-1252"; Format="flowed"
> Hi Bob,
> I would recommend something as simple as
> SELECT * from mytable where myfield = '@MYSTRING';
> I tried using a string variable in a PGScript once, too, and if I
> remember correctly, quote_literal() did not work.
> Good luck and regards,
> Birgit
> Am 24.09.2015 um 03:43 schrieb David Fawcett:
>> Bob,
>> David.
>>      DECLARE @MYSTRING;
>>      postgis-users at lists.osgeo.org <mailto:postgis-users at lists.osgeo.org>
> URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20150924/8ed2df10/attachment-0001.html>
> End of postgis-users Digest, Vol 163, Issue 11
