[postgis-users] invalid join selectivity: 179531936.000000
Paul J. Caritj caritj at gmail.com
Mon Sep 28 12:38:58 PDT 2015
Thanks everyone. I had mistakenly assumed that the bug Rémi and Imre have
pointed out would be fixed in 2.1.8. I haven't been able to upgrade or
patch, but the workaround of copying the data to a new table seems to work.
Thanks again,
Paul
On Fri, Sep 25, 2015 at 4:19 AM, Rémi Cura <remi.cura at gmail.com> wrote:
> Yep,
> I had the same problem
> https://trac.osgeo.org/postgis/ticket/2543
> The issue is that this bug is hard to reproduce.
> As a workaround, you can try to drop and recreate the table :
> DROP TABLE
> VACUUM FULL ANALYZE
> CREATE TABLE
> CREATE INDEX
> Cheers,
> Rémi-C
> 2015-09-25 1:32 GMT+02:00 Paul J. Caritj <caritj at gmail.com>:
>> Hello,
>> I am having trouble with what I expected to be a simple query. I have two
>> tables, one of census tracts (with a multipolygon geometry column, srid
>> 4269), and another of sites (with a point geometry column, srid 4269). I
>> want to find the number of sites that are within a tract of more than a
>> given population, so I've tried:
>> SELECT count(sites.id) FROM sites, census_tracts WHERE AND
>> census_tracts.population > 2000 AND ST_Contains(census_tracts.geometry,
>> sites.location);
>> But when I do this I get: psycopg2.InternalError: invalid join
>> selectivity: 179531936.000000.
>> Both of the relevant tables have been analyzed and vacuumed.
>> The output of postgis_full_version() is
>> POSTGIS="2.1.8 r13780" GEOS="3.4.2-CAPI-1.8.2 r3924" PROJ="Rel. 4.8.0, 6
>> March 2012" GDAL="GDAL 1.11.1, released 2014/09/24" LIBXML="2.7.8"
>> LIBJSON="UNKNOWN" RASTER
>> I'm using Windows 7.
>> Does this ring a bell for anyone?
>> Thanks very much!
>> -Paul
>> postgis-users mailing list
>> postgis-users at lists.osgeo.org
>> http://lists.osgeo.org/cgi-bin/mailman/listinfo/postgis-users
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20150928/29cba63f/attachment.html>
