[postgis-users] Using SRID with meters, but still not getting UNITS in meters with ST_DWithin
Lucas Fairchild-Madar lucas.madar at gmail.com
Mon Apr 11 12:43:49 PDT 2016
Nevermind, that won't work with your ST_DWithin query. You can create an
index using a cast if that's something you're looking for.
On Mon, Apr 11, 2016 at 12:42 PM, Lucas Fairchild-Madar <
lucas.madar at gmail.com> wrote:
> You can cast to geography only within your ST_Distance call to get meters:
> ST_Distance(t1.geo_position::geography,t2.geo_position::geography)
> That way the rest of your query will still use the index.
> On Mon, Apr 11, 2016 at 11:21 AM, Michael Moore <michaeljmoore at gmail.com>
> wrote:
>> I am trying to find all zip codes withing a given range of current zip
>> code. For example, User is at zip code 95076 and want to know all zip codes
>> within a 30 mile range. This will always be a short distance, nothing over
>> 50 miles. The source zip code is any place in the USA.  My input table has
>> a latitude field, a longitude field and a POINT field for each zip code.
>> I want to supply in input in meters, not degrees. I do NOT want to cast
>> to *geography* because this prevents the index from being used.
>> Here is a *working query* that uses the index, but ST_DWithin  is not
>> understanding ".05" as meters:
>> lcd1_dev=>   select t2.city, t2.postalcode,
>> ST_Distance(t1.geo_position,t2.geo_position)
>> lcd1_dev->   from      tpostalcoordinate t1
>> lcd1_dev->   left join tpostalcoordinate t2 on ST_DWithin(t1.
>> *geo_position*,t2.*geo_position* , .05)
>> lcd1_dev->   where t1.postalcode = '94404'and t1.countrycode2tcountry =
>> 'US' and t2.countrycode2tcountry= 'US';
>>      city     | postalcode |     st_distance
>>  Redwood City | 94065      |  0.0273766323714193
>>  San Mateo    | 94408      | 0.00504738546179631
>>  Belmont      | 94002      |  0.0440065904155286
>>  San Mateo    | 94404      |                   0
>>  San Mateo    | 94403      |  0.0370314731005901
>>  San Mateo    | 94407      |  0.0416118372581607
>> *This shows that I am using SRID 4896*
>> lcd1_dev=> select * from geometry_columns where f_table_name =
>> 'tpostalcoordinate';
>>  f_table_catalog | f_table_schema |   f_table_name    | f_geometry_column
>> | coord_dimension | srid | type
>>  lcd1_dev        | qsn_app        | tpostalcoordinate | geo_position
>>  |               2 | 4896 | POINT
>> *4896 is UNIT "metre" as show here:*
>>  4896 | EPSG      |      4896 |
>> GEOCCS["ITRF2005",DATUM["International_Terrestrial_Reference_Frame_2005",SPHEROID["GRS
>> 1980",6378137,298.257222101,AUTHORIT
>> Y["EPSG","7019"]],AUTHORITY["EPSG","6896"]],PRIMEM["Greenwich",0,AUTHORITY["EPSG","8901"]],
>> UNIT["metre",1,AUTHORITY["EPSG","9001"]],AXIS["Geocentric X",OTH
>> ER],AXIS["Geocentric Y",OTHER],AXIS["Geocentric
>> Z",NORTH],AUTHORITY["EPSG","4896"]] | +proj=geocent +ellps=GRS80 +units=m
>> +no_de
>> *The following (from EXPLAIN) proves that the index is being used in the
>> working query shown above:*   ->  Index Scan using tpostalcoordinate_pk
>> on tpostalcoordinate t1  (cost=0.42..8.45 rows=1 width=32)
>> What do I need to do to get this in meters without losing my index access?
>> TIA,
>> Mike
>> postgis-users mailing list
>> postgis-users at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/postgis-users
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20160411/6970a236/attachment.html>
