[postgis-users] attempt to redefine parameter "postgis.backend"
Paul Ramsey pramsey at cleverelephant.ca
Tue Apr 12 08:50:22 PDT 2016
What does this query return?
select distinct probin from pg_proc where probin like '%postgis%';
On Tue, Apr 12, 2016 at 2:32 AM, Armand Turpel
<armand.turpel.mnhn at gmail.com> wrote:
> Hi,
> I have a wired problem after upgrading from pg 9.1  postgis 1.5 to pg 9.3
> postgis 2.2.1
> On some tables with a geometry column the error appear:
> even if a query dosent contains the geometry column.
> On other tables which have a geometry column too the problem dosent appear.
> May some geometry columns are corrupted.
> I guess i have done some thing wrong with the pg/postgis upgrade. The mess
> is done. Since the last upgrade, 2 weeks, the database is in production. I
> cant easily restore the old database.
> Is there a way to fix this problem?
> Thanks for helping,
> atu
> postgis-users mailing list
> postgis-users at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/postgis-users
