[postgis-users] Raster tile size impact results
Pierre Bails bails at getredbird.com
Mon Aug 22 01:07:56 PDT 2016
Hi Pierre,
I have the same problem with or without the rescale function...
Pierre Bails
Le mar. 9 août 2016 à 14:30, Pierre Racine <Pierre.Racine at sbf.ulaval.ca> a
écrit :
> What if you remove the ST_Rescale() ?
> > -----Original Message-----
> > From: postgis-users [mailto:postgis-users-bounces at lists.osgeo.org] On
> Behalf
> > Of Pierre Bails
> > Sent: Thursday, July 28, 2016 4:28 AM
> > To: PostGIS Users Discussion <postgis-users at lists.osgeo.org>
> > Subject: Re: [postgis-users] Raster tile size impact results
> > Hi,
> > The full request is :
> > SELECT DISTINCT ST_AsGeojson(ST_Union((px.geom),4326))
> > FROM (
> >   SELECT *
> >   FROM dsm
> >     INNER JOIN
> > ST_SetSRID(ST_MakeValid(ST_GeomFromGeojson('{"type":"Polygon","coordinat
> > es":[[[],[],[],[],[],[]]]}')), 4326) AS geom on ST_Intersects(dsm.rast,
> geom)
> > ) AS inter,
> > ST_PixelAsCentroids (ST_Clip(ST_Rescale(inter.rast, 0.5), inter.geom),1)
> as px
> > Thanks,
> > Pierre
> > Pierre Bails
> > GIS Engineer
> > Redbird
> > EMEA - 16, rue de la Comète - 75007 Paris - France
> > US - 44 Tehama St, San Francisco, CA 94105 - USA
> > Mobile: +33 677 375 851 | US Office: +1 415 366 0191 | FR Office: +33
> 184 165
> > 201
> > bails at getredbird.com <mailto:bails at getredbird.com>  | www.getredbird.com
> > <http://www.getredbird.com/>  | Facebook
> > <https://www.facebook.com/redbird.drones>  | Twitter
> > <https://twitter.com/redbirdHQ>  | Youtube
> > <https://www.youtube.com/channel/UC9ab5NnNorfVcRdynbTzSLw/videos>
> > Le lun. 25 juil. 2016 à 21:30, Pierre Racine <
> > <mailto:Pierre.Racine at sbf.ulaval.ca> > a écrit :
> >       I will need to see your last query to try to find the problem.
> >       Pierre
> > <mailto:postgis-users-bounces at lists.osgeo.org> ] On Behalf Of Pierre
> Bails
> >       Sent: Wednesday, July 20, 2016 5:36 AM
> > <mailto:postgis-users at lists.osgeo.org> >
> >       Hi,
> >       Thank you for the tips.
> >       Well, I don't know why, but the st_clip function doesn't seem work
> fine.
> >       After clipping and dumping each pixel as point, some points follow
> tiles,
> > others follow the geometry. Any idea why ?
> >       For now, to avoid the problem, I apply a St_ContainsProperly after
> the
> > dump.
> >       Red : geometry
> >       Light blue : tiles
> >       Dark blue : pixels as points
> >       Thank you for your help !
> >       Pierre
> >       Le ven. 15 juil. 2016 à 17:28, Pierre Racine <
> >               Sorry for the late answer.
> >               You have to vectorize them on the fly from within OpenJump:
> >               SELECT (ST_DumpAsPolygons(rast).* FROM yourrastertable;
> >               If your raster is very big and tiled, just vectorize the
> tiles you
> > need:
> >               SELECT rid, rast::geometry FROM yourrastertable;
> >               Look at the rids and then:
> >               WHERE rid = x or rid = y
> >               Pierre
> > bounces at lists.osgeo.org <mailto:postgis-users-bounces at lists.osgeo.org>
> ] On
> > Behalf
> >               > Of Pierre Bails
> >               > Sent: Friday, June 24, 2016 12:32 PM
> results
> >               > Hello,
> >               > Unfortunatly, I don't find a way to print raster results
> in
> > OpenJump. Can you
> >               > explain me how I can do it ?
> >               > Pierre
> >               > Le lun. 20 juin 2016 à 16:16, Pierre Racine
> > <Pierre.Racine at sbf.ulaval.ca <mailto:Pierre.Racine at sbf.ulaval.ca>
> > <mailto:Pierre.Racine at sbf.ulaval.ca> > > a écrit :
> >               >       I would try to understand, visually using
> OpenJump, how
> > your tiles are
> >               > clipped in the two cases... I guess sometimes 1 pixel
> wide tiles
> > get clipped in a
> >               > strange way.
> >               >       Pierre
> > <mailto:postgis-users-bounces at lists.osgeo.org> > ] On Behalf
> >               >       > Of Pierre Bails
> >               >       > Sent: Wednesday, June 15, 2016 11:41 AM
> >               >       > To: postgis-users at lists.osgeo.org <mailto:
> postgis-
> > users at lists.osgeo.org>  <mailto:postgis- <mailto:postgis->
> >               > users at lists.osgeo.org <mailto:users at lists.osgeo.org> >
> >               >       > Subject: [postgis-users] Raster tile size impact
> results
> >               >       > Hi all,
> >               >       > I'm looking for get all pixel's value in a
> raster insert
> > thanks to
> >               > raster2pgsql
> >               >       > intersect by a polygon.
> >               >       > Nevertheless, there are some things that I don't
> > understand: depends
> >               > on tile
> >               >       > size, I don't have the same result... The error
> between 2
> > raster is also
> >               > correlate
> >               >       > to the pixel size (I assume it's due to the
> pixel number).
> >               >       > Can you explain me how the tile size can
> influence the
> > final result ?
> >               >       > Here is the query :
> >               >       > SELECT DISTINCT SUM((px).val)
> >               >       > FROM(
> >               >       >   SELECT *
> >               >       >   FROM  mns INNER JOIN
> st_setsrid(st_geomfromgeojson('{"type":"Polygon","coordinates":[[[x,y],[x,y],[x
> >               >       > ,y] ]]}'), 4326) as geom on
> ST_Intersects(mns.rast, geom)
> >               >       > ) AS clip, ST_PixelAsCentroids
> (ST_Clip(clip.rast,
> > clip.geom),1) AS px;
> >               >       > DSM px size 70cm:
> >               >       > raster2pgsql -a -t 250x250 -s 4326 -F
> pathToDSM.tiff
> > dsmTable (result:
> >               > 46 347
> >               >       > 846)
> >               >       > raster2pgsql -a -t 50x50 -s 4326 -F
> pathToDSM.tiff
> > dsmTable    : 46 382
> >               > 873
> >               >       > Difference: 35027
> >               >       > DSM px size 20cm :
> pathToDSM.tiff
> > dsmTable :  567
> >               > 505 888
> pathToDSM.tiff
> > dsmTable    : 596
> >               > 897 610
> >               >       > Difference: 29 391 722
> >               >       > If we considere 250x250's result as reference,
> there is a
> > difference of
> >               > 0.07% in
> >               >       > the first case, and 5% in the second. If the
> polygon area
> > increases, the
> >               > error rate
> >               >       > increases.
> >               >       > Thank you,
> >               >       > Pierre
> >               >       _______________________________________________
> >               >       postgis-users mailing list
> >               >       postgis-users at lists.osgeo.org <mailto:postgis-
> > users at lists.osgeo.org>  <mailto:postgis-users at lists.osgeo.org <mailto:
> postgis-
> http://lists.osgeo.org/mailman/listinfo/postgis-users
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20160822/c0024690/attachment.html>
