[postgis-users] Substantial different index use between 9.5 and 9.6 using Postgis
Regina Obe lr at pcorp.us
Sat Dec 3 11:53:05 PST 2016
For reference I have ticketed this as:
https://trac.osgeo.org/postgis/ticket/3675
---------- message ----------
Bill,
Never mind. Thanks to Brian Hamlin's nudging on IRC that he sees the issue
too, I was able to replicate it.
I think the reason I missed it in my testing is that it doesn't happen with
the more common cases of:
SELECT e.gid
FROM e1 , e2
WHERE ST_Intersects(e1.geom, e2.geom);
Or where you use constants in ST_MakePoint like your example
But only in case where you have:
SELECT e.gid
FROM e1 , e2
WHERE ST_Intersects(e1.geom, ST_SetSRID(ST_MakePoint(e2.longitude,
e2.latitude),4326)  );
So I'll go ahead and ticket it and try to track down the root cause.  I
suspect it affects all our relation functions.
Thanks for bringing to our attention,
Regina
http://www.postgis.us
http://postgis.net
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20161203/8f72fe38/attachment.html>
