[postgis-users] Functionality--Support
Pradeep pgundala at avineonindia.com
Mon Jul 18 03:51:41 PDT 2016
Please confirm below functionality will support in PostGIS or not?
1)         Spatial option that provides advanced spatial features to support
high-end GIS and LBS solutions
2)         Querying, and retrieval for 3-dimensional (3D) data including
points, lines, surfaces, triangulated irregular networks (TINs - an
alternative to raster's), and point clouds.
3)         Spatial queries can now run in parallel on partitioned spatial
indexes, improving the performance of "within distance", "nearest neighbor",
and "relate" queries
4)         SQL/MM types and operators, as specified in ISO 13249-3,
Information technology - Database languages - SQL Multimedia and Application
Packages . Operators corresponding to those defined in this standard, as
well as the SDO_NN and SDO_WITHIN_DISTANCE operators should be able to be
used on data stored in the SQL Multimedia root type
Thanks & Regards
Pradeep Kanth
Ext : 3026
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20160718/3ca43ab8/attachment.html>
