[postgis-users] Performance external loop, WHERE IN (values), stored procedure or else to pass data to SQL query
Rémi Cura remi.cura at gmail.com
Thu Jun 16 01:51:59 PDT 2016
Index not used can have a lot of causes:
1. the way you write the sql query,
2. a problem with statistics (vacuum analyze concerned tables)
3. a wrong tuning of postgres server (less common)
Most likely in your case is 1., but you can vacuum analyze the tables
first, it could be an easy fix.
Can you show the exact query you are using (along with the number of row
per concerned table)?
Cheers,
Rémi-C
2016-06-14 12:53 GMT+02:00 Michal Seidl <michal.seidl at gmail.com>:
> Hello,
> You understand my problem correctly. But despite I have sptatial index on
> geometry colum (points are 2D) one SQL query takes about 20ms only with
> operator && ST_GeomFromText('POINT..) && geom_column. This operator as I
> know works only with MBR (it should be same as equal for points)
> With other operators ST_Distance,ST_Equal, = the spatial index is not used
> (?) and query take about 500ms. 500 points x 500ms => 250s which is quite a
> lot and I do not take into account time spent on python side. That's the
> problem.
> Thanks Michal
> On 06/14/2016 10:36 AM, Rémi Cura wrote:
>> Hey,
>> I fiind it difficult to understand exactly your problem.
>> If you have a set of point A in python , of about 100 points,
>> and a set of point B, in postgres, of a few million points,
>> and that you want to find which point of A are already in B,
>> you wouldn't need to import your python points into a temp postgres
>> table and index it.
>> If your points are simple (for instance, only 2D, each dim an int),
>> you may skip postgis altogether.
>> Checking 100 points against few million should be <10ms with indexes.
>> You can check ta
>> 2016-06-13 20:46 GMT+02:00 Leknín Řepánek <godzilalalala at gmail.com
>> <mailto:godzilalalala at gmail.com>>:
>>     Python Array -> geometry(POINT, [SRID])[] -> unnest, you can use
>> unnest
>>     in CTE
>>     something like
>>     WITH cte AS (
>>              SELECT unnest(array['POINT(1 1)'::geometry ......]) pnt
>>     SELECT * FROM t JOIN cte ON ST_....
>>     Milions of points aren`t big data, if it is slow, maybe you should
>> check
>>     your indexes.
>>     On Mon, Jun 13, 2016 at 08:08:34AM -0700, Michal Seidl wrote:
>>      > Hello,
>>      > I have probably simple question but I am stuck. I have table with
>>     about 1E6
>>      > points in table. I have about hundreds of points in Python array.
>>     How to
>>      > pass these points into Postgis SQL query to check against table
>>     (if the same
>>      > point exist) with millions points?
>>      > I started with Python loop to check every point individually but
>>     it is slow.
>>      > I have found lots of receipts how to fight with large data but
>>     they have to
>>      > be already in database.
>>      > Which way is good for this situation?
>>      > - create temporary table and firstly insert points into DB
>>      > - try to manage Python not to close connection and send SQL query
>>     with each
>>      > point fast
>>      > - try to push all points in one query? How?
>>      > - write stored procedure that will accept array of data?
>>      > - anything else?
>>      > May be it is more general SQL questions, but i am working with
>>     points.
>>      > Thanks for advice Michal
>>      > View this message in context:
>> http://postgis.17.x6.nabble.com/Performance-external-loop-WHERE-IN-values-stored-procedure-or-else-to-pass-data-to-SQL-query-tp5010138.html
>>      > Sent from the PostGIS - User mailing list archive at Nabble.com.
>>      > _______________________________________________
>>      > postgis-users mailing list
>>      > postgis-users at lists.osgeo.org <mailto:
>> postgis-users at lists.osgeo.org>
>>      > http://lists.osgeo.org/mailman/listinfo/postgis-users
>>     postgis-users at lists.osgeo.org <mailto:postgis-users at lists.osgeo.org>
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20160616/190eec8d/attachment.html>
