[postgis-users] Raster SQL to separate high value areas
liglio at pobox.com liglio at pobox.com
Tue Mar 8 12:09:33 PST 2016
I am trying to separate areas of high value of lightning probability (above
70%) in a Raster and calculate their centroids. I successfully loaded a
GeoTiff raster image (one band, gray scale, 982x1108 pixels) in PostgreSQL
9.5 (Postgis 2.2.1). I see the SQL results in OenJump 1.9.
I used the next SQL, but the function ST_PixelAsPoints result in a geometry
points which are of the pixel's upper-left corner. I am not sure that is the
right way to do, because of that displacement. Can I do without this
transformation raster-geometry ?
Thanks.
SELECT row_number() over () AS id,
  ST_NumGeometries(gc),
  gc AS geom_collection,
  ST_Centroid(gc) AS centroid
FROM (
  SELECT unnest(ST_ClusterWithin(geom, 0.1)) AS gc
  FROM (SELECT (ST_PixelAsPoints(rast, 1)).*
    FROM tb_lightningprob) foo
    WHERE val > 0.7
) f;
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20160308/071b55fb/attachment.html>
