[postgis-users] Invalid Byte Sequence Error when using st_bandpath
Tumasgiu Rossini rossini.t at gmail.com
Wed May 11 05:49:44 PDT 2016
Hello list,
I came across an error using st_bandpath,
When using PostgreSQL binary output format, executing the function on
rasters registered with UNC paths fails with error message :
"22021: invalid byte sequence for encoding « WIN1252 » : 0x00"
When using Text mode, the functions works correctly.
My guess is that the first character of a UNC path which is a
backslash is considered as an escape sequence.
But it seems you can't escape the first two backslashes when
using raster2pgsql (tried \\\\, /\/\ and doublequoted path and
every combination of these three).
My configuration :
Windows 7
Postgres 9.3.5
Postgis 2.1.3
Database using WIN1252 Encoding and French_France.1252 collate.
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20160511/03f57d89/attachment.html>
