[postgis-users] Error enabling PostGIS extension
Regina Obe lr at pcorp.us
Tue May 17 22:06:46 PDT 2016
You need to upgrade your PostgreSQL 9.2 to higher than 9.2.3 - upgrade to
latest micro for 9.2
The PostgreSQL group changed the api somewhere between 9.2.5 and 9.2.7, I
forget.  So the PostGIS binaries on stackbuilder assume you are running a
newer PostgreSQL 9.2 micro.
It's rare they make such a change in a micro release, but they had to and it
broke a lot of old install packages, forcing packagers to build new ones.
Hope that helps,
Regina
From: postgis-users [mailto:postgis-users-bounces at lists.osgeo.org] On Behalf
Of Kevin Berger
Sent: Tuesday, May 17, 2016 3:52 PM
To: postgis-users at lists.osgeo.org
Subject: [postgis-users] Error enabling PostGIS extension
We installed the 64-bit version of PostgreSQL database, version 9.2.3. We
then downloaded and installed postgis-bundle-pg92x64-setup-2.1.8-1.exe. When
we try to create a postgis extension in our PostgreSQL database, we get
error:
Is there anything we can do to fix this?
Kevin
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20160518/3c93c401/attachment.html>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20160518/3c93c401/attachment.png>
