[postgis-users] Topology Issue Reported by Query but Not Identified with ST_IsValid
Michael Treglia mtreglia at gmail.com
Thu May 26 19:33:41 PDT 2016
Hi All,
I was running a query involving ST_Difference between two multipolygon
layers, and a while in, it threw this message:
ERROR: GEOSDifference: TopologyException: side location conflict at
919670.1768945494 140665.82566365649
However, I previously ran ST_MakeValid, and ST_IsValid doesn't report any
objects with problems. Is there something I'm missing, or something else I
need to check? (Apologies is this is just a naive question - still learning
my way around PostGIS).
And in case it helps, here's my SQL:
CREATE TABLE SI_Unclaimed AS
SELECT gid, COALESCE(ST_Difference(geom_2263, (SELECT
ST_Collect(b.geom_2263)
                                         FROM citywide_basedata.parcels15 b
                                         WHERE ST_Intersects(a.geom_2263,
b.geom_2263)
                                         )), a.geom_2263)
FROM citywide_basedata.boroughs_nowater a where boroname like 'Staten
Island';
Thanks!
Mike
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20160526/0bf901b3/attachment.html>
