[postgis-users] "non intersecting node" error when using st_node ?!
Mathias Versichele mathias.versichele at gmail.com
Tue Sep 27 05:55:46 PDT 2016
Hi all,
I've been struggling with "non intersecting node" issues when trying to run
st_node, which seems weird to me as st_node is supposed to fix these issues
in the first place, right ?
The following table dump illustrates the problem: https://we.tl/d3WwOv2AFv
When running the following query:
select st_node(st_collect(geom)) from input_geoms;
I get the following error:
ERROR:  GEOSUnaryUnion: TopologyException: found non-noded intersection
between LINESTRING (1.0708e+06 786844, 1.07094e+06 786875) and LINESTRING
(1.07097e+06 786883, 1.0708e+06 786844) at 1070922.7377618756
786871.60839152802
The input geoms are already snapped to 10meters precision.
Help very much appreciated on how to fix this issue.
Mathias Versichele
Oudburgstraat 16
9240 Zele
0485/16.07.08
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20160927/eba91427/attachment.html>
